Raster and image size question on Cine 9
Posted: Sun Jul 14, 2013 6:14 am    Post subject: Raster and image size question on Cine 9
Im just doing some setup here, ive got the machine back just a touch further than the Barco lens program says, and the tube face seems almighty full...
Is this normally ok on these machines?
The image there doesnt fill the width of the screen by about an inch each side, so it is a touch wider on the faces.
Posted: Sun Jul 14, 2013 7:14 am    Post subject:
Well, it's not centered right... I think only the NECs are so picky on raster size, so you should largen the image unless you go off the tube (on the left there is some more space to fill in -as I'm seeing from here, though I'm quite far away Very Happy)
Posted: Sun Jul 14, 2013 7:47 am    Post subject:
It is centered, just took the pic off center which causes that look.
Im setting up 16:9 at the moment and there is alot more free space at the sides with that.
Amazingly enough its not like the NECs where you will probably re center the raster after adjusting convergence, but then the convergence system on this machine is sh*t compared to the NEC system. The NEC has much more control, or certainly seems to.
Id be interested to know why the image is shimering though, would this be a product of the contamination present in the blue tube? All 3 are doing it, at varying rates depending on whats on the screen. Its on 1080i at the moment.
Posted: Sun Jul 14, 2013 8:21 am    Post subject:
CasetheCorvetteman wrote:
...but then the convergence system on this machine is sh*t compared to the NEC system. The NEC has much more control, or certainly seems to.
Nooooo, the cine 9 is the machine that has the best convergence system ever, didn't ya know? Twisted Evil
As for the shimmering: Isn't there some menu option for setting the signal clamping?
Posted: Sun Jul 14, 2013 9:32 am    Post subject:
There is, but i havent looked.
Whoever said this is the best convergence system ever is fulla sh*t son, NEC system is much better Wink
Some voltages
Posted: Sun Jul 14, 2013 9:47 am    Post subject:
Well i just tried IRIS, and that made it worse Laughing
Posted: Sun Jul 14, 2013 11:01 am    Post subject:
What screen are you using.? 16:9, or 4:3.?
Ill also say its not centered right, and if your using a 16:9 screen you need to make the raster bigger.
Dont you have a aspect ratio test pattern you can display, so its 100% sure how close you are on the left side.?
Dont you get visible scanlines running 1080i?
Posted: Sun Jul 14, 2013 12:27 pm    Post subject:
It is centered perfectly in both X and Y. Screen is 5:4, and the image seen on the tubeface was not filling the screen.
No scanlines visible from where i sit, my eye sight isnt that good.
Here are some pics from the bluray player.
Posted: Sun Jul 14, 2013 12:28 pm    Post subject:
Posted: Sun Jul 14, 2013 12:32 pm    Post subject:
Are you running 1080i 120hz.? ot whats the reason to use so low resolution on a 9" LUG tube.?
ElTopo
Posted: Sun Jul 14, 2013 12:40 pm    Post subject:
Cine 9 image is simply stunning !
How loud is the projector?
Barco Cine 9 the one and only
Posted: Sun Jul 14, 2013 1:44 pm    Post subject:
No im using 1080p @60Hz
Can hardly hear the fans, the buzzing sounds it makes at certain images is abit of a concern!
Posted: Sun Jul 14, 2013 2:14 pm    Post subject:
ElTopo
Posted: Sun Jul 14, 2013 2:18 pm    Post subject:
What is your source ? VP or directly from a blu-ray player?
Posted: Sun Jul 14, 2013 2:40 pm    Post subject:
Straight from the Panasonic bluray player via a MOOME V3 box into port 3
Posted: Sun Jul 14, 2013 2:47 pm    Post subject:
You know, the Barcos are programmed to blow up if you insult them. Careful what you say...Razz
ElTopo
Posted: Sun Jul 14, 2013 3:08 pm    Post subject:
Does the panasonic got any color calibration settings ?
Otherwise the Cine 9 has the options like D6500 inside to calibrate correctly.
Posted: Sun Jul 14, 2013 9:31 pm    Post subject:
Not that i know of, i always left it alone and used the projector, in this case itll be hard to get right cause the blue has a contamination issue and wont go completely black. Also taking the pics with the iPhone 4S as well. Which levels do you think need to change? Do you know what they all do?
Yeah i made sure i went outside before i typed that Wink
mx83toy
Posted: Mon Jul 15, 2013 12:02 am    Post subject:
about time you got this baby!!! cant wait to see what you get out of it...Good luck man!!!
Posted: Mon Jul 15, 2013 12:17 am    Post subject:
Cheers mate Wink Still yet to adjust the astig but im getting around to it all.
As it turns out, im using more tubeface than the previous owner, which is giving me a band down the sides that is ever so slightly brighter, not that it matters cause at some point they left the start menu of a yoga DVD on the screen and its burned in bad enough to see it on the screen. Although it wasnt listed in the auction, its pretty plain to see when you look at the tubefaces so i find it very hard to believe they didnt know it was there.
