Replacement parts for Panasonic PT-AE 900 needed
tschaeikaei
Posted: Fri Jul 12, 2013 5:32 pm    Post subject: Replacement parts for Panasonic PT-AE 900 needed
Hi, I'm looking for a replacement lens for an Panasonic PT-AE900 E.
I don't know yet what this lens is called, but I will give a description.
Maybe a lens from an PT-AE 700 will help, too. They seem to be nearly the same projectors,
exept the IRIS.
Ok, short description:
The lens is located near the bulb in an array of lenses. It is build of some glas-segments.
The only picture I found is here:
Ignore the pink arrow, the one I'm looking for is the second from left side (RED arrow).
It has a metal sheet to hold it in position.
Maybe someone shouts "Here, I got some old Panasonic stuff!"
So thank you and best regards, Julian
PS: My girlfriend said a CRT would be to large and complicated for her room, thats the reason i bought this
3 LCD thing...
Posted: Fri Jul 12, 2013 7:23 pm    Post subject:
That appears to be the beam splitter. What is wrong with the one in the projector?
tschaeikaei
Posted: Sat Jul 13, 2013 12:46 am    Post subject:
The projected image is very dark. I bought the projector it last week, and the seller said something about the lamps
life end.
But the lamp was very very bright when I fired it up outside the beamer chassis. I compared to a
150W VIP R lamp on the same SMPS, it was nearly the same brightness.
So I disassembled the projector and found lots of dust and nicotine.
The beam splitter lens is burned, the coating on one side was brown. I scratched the brown coating off,
cleaned most of the lenses and put everything back together. Much higher brightness now, but still way to dark.
The other problem I've seen: on the left side of the screen I got to much blue (it's a 3 LCD), maybe I should not
have loosened the screws of the mirror before the blue LCD. But it is not that much and I could live with it.
But what about that beam splitter lens? What is it's exact job? If someone has a new one (or used) I replace it.
What would happen if I just take it out and run the projector without that lens?
Regards, Julian
Posted: Sat Jul 13, 2013 12:52 am    Post subject:
It's hard to tell from your image if your pointing to the beam splitter.
Is this what it looks like removed?
tschaeikaei
Posted: Sat Jul 13, 2013 1:24 am    Post subject:
Have you seen Inglorious Basterds? "That's a Bingo!"
I searched Tectron.it, but... can you give me a link to the right part?
Thank you very much so far.
Posted: Sat Jul 13, 2013 1:29 am    Post subject:
This should be the correct part for your model.
http://www.tectronelectronics.eu/pbs.html?sl=EN
These are the other models that are suppose to be the same if you decide the new one is to pricey and want to hunt down a used one.
PTAE700U
PTAE900U
PTAX100U
PTAX200U
PTLB20NTU
PTLB20SU
PTLB20U
PTLB20VU
tschaeikaei
Posted: Sat Jul 13, 2013 12:06 pm    Post subject:
Oh yes, thats to expensive. I payed about 80$ for the rest of the projector.
Thanks for the other models Smile
Again the question: Does it make sense to try the projecto without that lens?
Or does this lens have such a big effect on the picture?
Is it possible that it (the damaged one thats build in my proj) effects the blue color
that I have to much blue on the left part of the screen ?
Regards, Julian
PS: I will reply here when I buy this lens. Until then, you can PM me if you
have one or a (cheap/ broken) projector, one in macgyvers list.
tschaeikaei
Posted: Fri Jul 26, 2013 6:43 pm    Post subject:
Hey, I ordered a PCE lens from here http://stores.ebay.de/Beamerbude-Berlin.
It is a used one for 20€ (approximately 25$) , but let's see how it will be working.
Just in case someone is looking for spare parts, I think this is a cheap address.
Don't know if he has other than Panasonic parts, but I think so.
Regards, Julian
I received the lens some days ago. Very good condition, an air-filter as extra gift.
I recommend the seller stricktly, just in case someone is looking for digital- projector spare parts.
Regards, Julian
