Thank you Windows
Phoenixed
Posted: Thu Jul 04, 2013 4:32 am    Post subject: Thank you Windows
Moved a hard drive to an USB enclosure and Windows decided to LOCK (or in its own words GPT Protective)my 3TB drive full of movies. Now I have to decide which ones to MANUALLY restore, through basically verbose commands, to a smaller hard drive and which ones will be deleted using the CLEAN command...
Planar PD-8150/Runco LS-5
fuchs
Posted: Thu Jul 04, 2013 12:41 pm    Post subject:
Can't you put that drive back into a 64-bit machine and copy your things to another drive from there?
Then clean it and put it back in the USB enclosure.
onkel fuchs' cheapskate cinema
NEC plain 9PG
Posted: Thu Jul 04, 2013 4:19 pm    Post subject:
What fuchs said? Is it not accessible through a linux os?
Phoenixed
Posted: Thu Jul 04, 2013 5:29 pm    Post subject:
I appreciate the help, but I don't have a big enough drive to copy all of it nor enough drives. The drive is accessible, just not in the graphical sense. I am using a program called testdisk to restore the files, the ones I can anyways.
My understanding is that Windows during installation sees the drive, sees it uses GPT, then installs a unique identifier hash into the partition as a form of security. This I believe prevents Joe Blow from walking past a server and taking out a drive to view the data. I guess I could try gparted in Linux but I believe the unique hash will be an issue.
I could be completely wrong in my theory.
Posted: Thu Jul 04, 2013 6:19 pm    Post subject:
What flavor of windows are you using ?
Phoenixed
Posted: Thu Jul 04, 2013 7:00 pm    Post subject:
Windows 8.
This has been an issue with Windows 7 when GPT partitions became more mainstream due to larger hard drives.
I mainly posted so everyone here is aware of the issue and to vent.
the big E
Posted: Mon Feb 16, 2015 7:33 am    Post subject:
I never use the gpt format and don't recommend due to this very issue
crt king of black
Posted: Wed Apr 15, 2015 3:25 am    Post subject:
Errrmmm.... What???
Do you still roll with Windows XP too Evan???
Ive moved drives between PCs and not had that issue yet, youll have issues using a drive or array larger than 2TB if you dont step up.
the big E
Posted: Wed Apr 15, 2015 4:08 am    Post subject:
CasetheCorvetteman wrote:
Errrmmm.... What???
This is what happens when I don't get much sleep haha(DOH)
I stopped using xp when Microsoft dropped support but I do have a xp machine still(don't use it much)it may see more use now that I have a tech-2 for my caddie
I always use the defaults when formatting a drive unless it's for a ipod drive(have to have them unformatted)
crt king of black
