1209s boards/electronics into Cine9 chassis ?
ElTopo
Posted: Mon Jun 17, 2013 1:02 pm    Post subject: 1209s boards/electronics into Cine9 chassis ?
Is this possible?
What do you think?
Take all the stuff out of the Cine9 chassis and put in all from a 1209s.
ElTopo
Barco Cine 9 the one and only
Posted: Mon Jun 17, 2013 1:03 pm    Post subject:
The big question is... why bother?
There's many hours worth of work, the convergence trays are completely different, but hey, the tube mounting is the same. Smile
ElTopo
Posted: Mon Jun 17, 2013 1:14 pm    Post subject:
That was also my first idea Curt Cool
SisterOfMercy
Posted: Mon Jun 17, 2013 3:23 pm    Post subject:
And that's about it.
Most schematics do look the same, the RGB input boards and RGB driver are mostly unchanged. But the pinout is probably different.
The kissing and the colour come crashing down
TbX
Posted: Tue Jun 18, 2013 3:32 am    Post subject:
a 808 chassis fits right into a 909 the only thing that does not fit into existing holes are the control board above the modules
take the necboard from a 808retroblock and they fit right on the tubes
still to be tested is to plug in a 909 focusyoke to 808 chassis
//Tomas
ElTopo
Posted: Tue Jun 18, 2013 11:32 am    Post subject:
Can P19Lug's be used with BG 808s/Cine8 electronics ?
TbX
Posted: Wed Jun 19, 2013 2:00 am    Post subject:
Yes all thats needed is a nec board with panasonic pinout
Posted: Wed Jun 19, 2013 6:59 am    Post subject:
Similar idea to my setup, 808s electronics and 9" tubes only difference is I am using Sony tubes. Image is great and the 808s electronics are reliable and there are plenty of parts.
ElTopo
Posted: Wed Jun 19, 2013 6:49 pm    Post subject:
So that means P19Lugs are plug 'n play with a BG808s?
Leave all the Hardware attached on the tubes or using the 808s one ?
Posted: Wed Jun 19, 2013 8:20 pm    Post subject:
I can tell you that the Sony tubes are plug and play. I don't use Panasonic tubes so there could be a difference in pin out from 8 to 9. There should be pin out for those tubes on this site. Alternatively if there is a difference then perhaps the neck boards from a 1209s.
