Toooooooooooooooooom my meter is NOT Display 3!
This forum is locked: you cannot post, reply to, or edit topics.   This topic is locked: you cannot edit posts or make replies.    CurtPalme.com Forum Index -> ChromaPure Products
Decibel
Posted: Mon Jun 10, 2013 10:28 pm    Post subject: Toooooooooooooooooom my meter is NOT Display 3!
Very Happy
I just purchase today Chromapure standard + autocal add-on
Unfortunately the software not recognize my meter that is an x-rite i1 Display Pro
Please correct license file Thumbs Up
Domenico (Barco fan!)
Posted: Mon Jun 10, 2013 11:01 pm    Post subject:
That is the Display 3 . Same one.
Decibel
Posted: Mon Jun 10, 2013 11:22 pm    Post subject:
Sorry, perhaps I've wrong to connect the meter.
Now fixed!
What's the choice for crt projectors in the select initialize menu?
There are several options: standard, crt (but I think TVC), plasma etc...
Posted: Mon Jun 10, 2013 11:25 pm    Post subject:
I always use Standard.
Decibel
Thank you Nashou Wink
Decibel
Posted: Tue Jun 11, 2013 10:37 am    Post subject:
I read many times the grayscale guide
http://www.chromapure.com/movies/grayscaleLumagen/grayscaleLumagen.html
When I open manual control, all default values are different of the guide above
10% White = R G B LUMA = 0 0 0 0
20% White = R G B LUMA = 100 100 100 100
30% White = R G B LUMA = 200 200 200 200
etc...
White = R G B = 1024 0 1024
It's normal?
I've a Lumagen Radiance 2041
Corleone88
Posted: Thu Dec 19, 2013 2:47 pm    Post subject:
Did you try CRT and see a difference with Standard?
Posted: Thu Dec 19, 2013 5:23 pm    Post subject:
Yes, standard worked better as in faster readings and less variation with repeat readings.
it is meant for direct view CRT.
This forum is locked: you cannot post, reply to, or edit topics.   This topic is locked: you cannot edit posts or make replies.    CurtPalme.com Forum Index -> ChromaPure Products All times are GMT
