Marquee.. Possible convergence board improvements.!!
Posted: Tue May 28, 2013 5:15 pm    Post subject: Marquee.. Possible convergence board improvements.!!
Some time ago i was so unlucky, or stupid to let the smoke out of my Ultra convergence board, and was forced to repair it.
While waiting for parts, i was looking and checking the components over and over again, there is nothing i hate more than blowing stuff 2 times.
Suddently it made sence to me the way the convergence is drifting on the Marquee.. The 3 channels are not identical, Red channel having all its transistors on one side of the board, while blue and green was split on top and bottom of the board.
I have messed a lot with thermal cupling on power amps, and its the same thing that happens with DC drift when all transistors dont have the same thermal conditions.
I asked Curt for some defect convergence boards i can play with, and got them yesterday.. I repaired one of them right away, and tested it, its working.. It needs a bit more love, someone changed the caps and the 24V supply resistors, and dident do a very nice job, and a blown red chanel had been atempted repaired, with not to much luck.
Well the main idea is to get this board up running perfect, i have replaced all 1,2ohm resistors and 2ohm resistors with new 0,6w 50ppm resistors, and will do the same to all the resistors in the 24V suply, and the jumpers on the 24v is removed.
When i know what all these resistor changes do, ill continue moving ½ the red output transistors.. Q100 Q101 Q102 Q103 Q104 to the other side of the board, giving red convergence channel same thermal conditions as the others.
Anyone have some experience with this ?
I like to improve the drifting without adding active coling.
Posted: Tue May 28, 2013 6:02 pm    Post subject:
I am pretty sure electrohome also suggested at least 20minute warm up time for the projector, after the 20 min. the heatsink should evenly warm, so tthe thermal difference could've been ruled out. Of course there are a lot of possibilities. My 7500 was rock solid I think.
Posted: Tue May 28, 2013 6:32 pm    Post subject:
Its in my My Marquee thread. MP suggested many years ago to get larger Resistors to help with drift and to also clean the thermal
contact of the amps to the heat sink. the faster everything gets to operating temp the less drift there will be.
Posted: Tue May 28, 2013 6:33 pm    Post subject:
Sure 20 min do a lot to it, but it would be cool if its ready to fly 1080P after 2 min. And have less drifting.
Im sure everyone with a well setup Marquee running 1080P is tweaking convergence some times.
I do.. on all 3 Marquee i have.. And they all need more adjustment to red, i think red is actualy the one most stable, blue and green shifts right under heatup, so the idea was to make red do the same.
And if changing some resistors to low ppm helps, then they it should also be less sensive to temperature changes.
Posted: Tue May 28, 2013 6:37 pm    Post subject:
Sure, but that dont change that you have a different behavior on red. The heat sink will always have different temp in top and bottom.
And i dont have stable room temperature, so depending if its a hot or Cold day, i will never have the same operating temp.
Posted: Tue May 28, 2013 7:03 pm    Post subject:
You should notice that there are three smaller and two bigger transistors in each amp, the small transistor tied between the two big is responsible for the thermal stability of the amplifier, you should try to improve their thermal coupling further. Anyway, how serious is the convergence drift during warm up (expressed in test pattern thickness)?
Posted: Tue May 28, 2013 7:29 pm    Post subject:
Actually, what I would find an interesting experiment is to replace the analog (class AB) amplifiers with class D amplifiers. This would mean reduced heat consumption (increased efficiency), and maybe less heat dependence...
Posted: Tue May 28, 2013 8:48 pm    Post subject:
I dont think ill want to reconstruct the board, thats a compleetly different thing.
The thing im focused on here is the obvious non symetrical layout of the Marquee concergence board, and how easy it is to try change it.
There is many ways to attack this problem.. Design a watercooled convergence board .. its possible.. but not sure anyone like to pay for it..
Keep the budget low.. Wink
jbmeyer13
Posted: Tue May 28, 2013 9:19 pm    Post subject:
I replaced all of the caps on the Convergence board with 120/50 wet tantalums last June and my convergence is spot on for 800p/72, 1080p/60 and 1080p/48 within 5 minutes. No drift thus far.
Now if only I can get rid of the damn line produced by the VIM Rolling Eyes
Posted: Tue May 28, 2013 9:27 pm    Post subject:
I dont understand how the caps have any effect on DC drifting..?
Unless the convergence amp is getting hotter from working with some noise, but i have different caps on different boards, never seen any difference there.
What is temperature on your concergence board.
jbmeyer13
Posted: Tue May 28, 2013 9:40 pm    Post subject:
Never checked the temp. Prior to changing out the caps it would take 15-20 minutes for my convergence to stabilize and there was slight drift over time.
One other issue to consider is mechanical set up. The better that is I believe the less strain on the CVA. I wish I could provide you with a more academic answer on the CVA/caps but it's simply what I have found as a result. I also replaced caps on Astig and VDM but I don't believe that made any difference to the image.
Posted: Tue May 28, 2013 9:56 pm    Post subject:
neither do I, and I've also swapped the caps - many times.
Here's what I've found so far:
The change that most see after replacing the caps comes from removing the board from the heat-sink and then reinstalling it. You can check this yourself by reinstalling the old caps.
One of the problems with the radical drifting is the heat-sink isolator being aged and loosing its ability to properly transfer heat from the device to the aluminum heat-sink surface. Removing a cleaning the isolator does wonders, but it does not completely solve the problem, because a little more attention is also needed.
I also think you're on to something with your recent observation, because one thing that's been very common on all Marquess is the problem with the RED drifting being so different from the Blue and Green.
However, I'm also thinking that the problem could be somewhere else, because the problem is more static than zone. The convergence board deals with the zone only. The static is done from the deflection boards (vert/horiz).
These projectors have no respect of cap brand.
Posted: Tue May 28, 2013 10:00 pm    Post subject:
What line are you talking about??
If it's the line that's about 1/4 or 1/3 way in from the right of the image. That line is transmitted from the HDM into the video chain.
Is it the far right edge line?
jbmeyer13
Posted: Tue May 28, 2013 10:11 pm    Post subject:
Well in my case I had removed the back plane boards multiple times for maintenance, trying different caps, etc. and never saw any change to conv stability until trying the wet tantalums. If not the caps then it sure is an interesting coincidence. What on the HDM/VDM do you feel could be causing the issue?
jbmeyer13
Posted: Tue May 28, 2013 10:15 pm    Post subject:
The line you and Barclay were working on resolving that i have PM'd you about a couple of times. You said you were going to post the fix for this issue. Here is an example: https://www.curtpalme.com/forum_archived/viewtopic.php@t=32865.html
It has nothing to do with the CVA, just the one thing that annoys me more than anything else Evil or Very Mad .
Posted: Tue May 28, 2013 10:18 pm    Post subject:
What is the line issue. is it the edge line of the one in from the edge of the screen?
Wet tants are great for audio (50 or 60hz). Video is a whole different beast, with its 100 to 500kz hertz power supply rails.
Posted: Tue May 28, 2013 10:25 pm    Post subject:
I think your right, its a mix. Maybe the biggest isue is all the conections, i get changes unplugging and plugging back boards, it dont seems possible to touch anything without having to touchup convergence.
And then its drifting more the first day or 2 and later it gets quite stable.. like changing contact impedance somewhere..
I hope removing the jumpers on the convergence board on the 24v supply will do something. At least eliminate a possible changing conection.
jbmeyer13
Posted: Tue May 28, 2013 10:32 pm    Post subject:
The vertical line is on R/B channels as shown in that thread
Posted: Tue May 28, 2013 10:49 pm    Post subject:
That line you'll have to live with, at least for now. The only way around it is a MP modified VIM..Laughing
It's actually still there with my VIM, but only when looking into the tubes will you see it with no image showing, but not when image is present.
Posted: Wed May 29, 2013 3:35 pm    Post subject:
Now I think I've found out the ultimate solution Very Happy But certainly nobody would willing to do it...
During retrace the convergence amp probably stays idle, ie. 0V output, so, at that period one should take a sample of the output (and hold it until the next measurement is done), that would give the DC drift of the amplifier compared to ground, with thess a servo circuit would be able to set the lowest possible DC drift, and re-set in every retrace period.
As I understand the amplifier is a fully current feedback construction, so the impedance change of the yokes (due to the heat) would directly affect the gain factor, thus the DC drift.
