jamsys
| Posted: Tue May 28, 2013 1:31 am Post subject: Quick question |
I know wrong forum, but the guru's hang here...
Re-did the theater. I have two pair of new in-walls. One is 6" and the other 8". Which ones on side and rear. Both getting same powe from same amp. BK REF 5x250
Thx
Scott
the big E
| Posted: Tue May 28, 2013 4:52 am Post subject: Re: Quick question |
| jamsys wrote: | I know wrong forum, but the guru's hang here...
Thx
Scott |
Smaller speakers for rear and side larger speakers for front and center
I have 8inch infinity speakers for front and smaller ones for rear and side channels
jamsys
| Posted: Tue May 28, 2013 5:03 am Post subject: Re: Quick question |
| the big E wrote: | | jamsys wrote: | I know wrong forum, but the guru's hang here...
Thx
Scott |
I have 8inch infinity speakers for front and smaller ones for rear and side channels |
Already have larger front and center, just don't know where to put the larger set, side or rear...
the big E
| Posted: Tue May 28, 2013 5:08 am Post subject: Re: Quick question |
| jamsys wrote: | | the big E wrote: | | jamsys wrote: | I know wrong forum, but the guru's hang here...
Thx
Scott |
Already have larger front and center, just don't know where to put the larger set, side or rear... |
I would put the 6inchers in the rear then since the side speakers get used during 5.1 movies(depending on recivier configuration) and use the 8inch set for the side channels
That way you have the bigger speakers in front and beside you with the smaller speakers behind you just keep in mind I am not taking into consideration the wattage of the speakers(that is also a factor)
| Posted: Tue May 28, 2013 6:06 am Post subject: |
As long as the tweeter is the same in all it wont really matter a great amount, but i too will say put the 8" at the sides, slightly behind the listening point. ( about 100° or so is where i went. )
