Professional Help! - Record PS3 and Cable TV
rabarbosa
Posted: Thu Apr 25, 2013 4:25 am    Post subject: Professional Help! - Record PS3 and Cable TV
Hey guys I have a lot of question about record images. I hope that someone can help me.
I'm from Brazil but now I'm in the USA and I will go back to Brazil in June.
I want to record my gameplays and Cable TV easily. I looked a lot in the internet but I cant find a definitive solution for my case.
My Equipments:
PS3/Bluray/NetHD (the last one is Cable TV) - > HT-SS380 Sony by HDMI - > Panasonic Plasma GT30B by HDMI ARC
Headset Sony 7.1
Laptop i7 (good configuration)
Target:
Record Cable TV and PS3 in a easily way, a way where I dont need to change the cables everytime.
Possible game captures:
Avermedia Game capture HD
HD PVR1
HD PVR2
Elgato Game Capture HD
Connections:
Splitter HDMI after my HT, one output to TV and the another one to a game capture. I think that is the best way to dont need chance the cables, I am right?
Problems
1 - Game capture by HDMI
How to win the HDCP, using external game capture? Do you know if I can use some software to show and record the image in my laptop using HDPVR2 or Elgato?
2 - Game capture by component cable
I can use a conversor HDMI to component (after the splitter) and connect the output in the AverMedia Game capture HD or HD PVR1. Do you know if I will lost quality with this connection? Do you know if I can convert the HDMI signal to component without problem with the HDCP? HD Fury is the best solution? Which model of the HD Fury is ideal for my situation (PS3/Bluray/Cable TV)?
3 - Headset Sony 7.1 (It is not Pulse)
When I turn on the H7 the sound dont pass by HDMI, so I cant record by component or HDMI. I did a test to try fix this problem, I modify the output settings to multiple output, used the composite cable to check if the sound will pass, but I didnt have succes. In another words, when the H7 is on I cant use another source of sound. Do you know how I can fix this? Do u think that I need to buy another headset? What kind of headset?
I really need to use the H7 because I'm married and always I play at night, so is impossible play without H7. In the beggining I thought that to solve this problem will be very easy, but now i think totally different... is really hard.
Thank u for the help[/u]
bigge3415
Posted: Sun Apr 28, 2013 11:13 am    Post subject:
Geffen makes a pvr with an hdmi passthrough you could use a similar device with an hdmi switch.
