Brennithechamp
| Posted: Fri Apr 19, 2013 2:15 am Post subject: Need help deciding to switch to CRT |
Hey guys! I'm completely new to projectors, but found a BARCO 708s for sale and am very heavily considering switching to it! I'm good at tinkering and am going into College as a Computer Engineer but I have a few concerns regarding CRT projectors.
The first one is lighting. The projector will be going in my Dorm room and I'm wondering if slight ambient light is okay, or does my room have to be completely dark? I can make blinds to shut out light but still can't guarantee they'll be perfect.
My second concern is the image quality. I will be using it mostly for gaming and watching movies, and the video will be fed from a Denon AVR-391 and I'm wondering if the image will be comparable to a 720p DLP projector? I know that because of CRT there are less or no pixels which is a huge plus, but the only experience with CRT I have is old CRT and rear projection TVs, and from memory the images from those are less than favourable.
Thanks for reading and dealing with my newness to this whole thing!
Brendan
_________________ I'm new to projectors! If you have any advice don't hesitate to share!
mx83toy
| Posted: Fri Apr 19, 2013 3:46 am Post subject: |
Get some curtains for those blinds the darker the better... be very careful as crt's are very addictive before you know it you have 15 or em laying around in bits
| Posted: Fri Apr 19, 2013 4:09 am Post subject: |
REad this:
http://curtpalme.com/CRTPrimer.shtm
The 708 is a good unit... if the tubes are OK, and the chassis doesn't puke. It's one of the less reliable sets out there, but can be fixed and if the tubes are OK, then it can throw a great picture. It is a 720p set only, it can't lock to a 1080p image, not that you need that anyway.
Assuming the set is under $100, grab it regardless, and play and learn. If it's over $100, let us know how much, as the seller may be way overestimating what the (former) $18K projector is now worth.
As mx83 says, if you get addicted, you'll be trolling Craigslist weekly looking for a newer better unit, but the 708 is a good start.
Overall, a DLP will look sharper, but the CRT will look more natural by far.
| Posted: Fri Apr 19, 2013 4:23 am Post subject: |
| mx83toy wrote: | Get some curtains for those blinds the darker the better... be very careful as crt's are very addictive before you know it you have 15 or em laying around in bits  |
I resemble that remark.
mx83toy
| Posted: Fri Apr 19, 2013 4:24 am Post subject: |
I've had mine at 1080p but start off at 720p looks great at that res... Other cool thing they they are newb friendly as the have a component in use input number 45 or 6 mines been busted for awhile read the manual it will seem like a different language but will make sense when you get going... They are a cool machine hd 145 colour corrected lens's (very sort after) schemflug adjust ect ect leave electronic focus even the g2 alone till later on
| Posted: Fri Apr 19, 2013 5:03 am Post subject: |
Itll still do 1920x1080i though Curt!!
In the right conditions itll smoke a 720p DLP in my opinion.
Jeremy112
| Posted: Fri Apr 19, 2013 5:28 am Post subject: |
Even at 720p, or at 1366x768 (which is what I use for a PC to the NEC XG) CRT can blow away 1080p, just for the pure smoothness of the image while moving. The colors, the REAL contrast ratio, man it makes me want a G90 all over again!
You can use a CRT in ambient light, sometimes I don't dim it down all the way since its nice to be able to see other people when using the computer with the projector. I can see the reflected light, but since its about 10 feet away from the screen it really isn't that bad.
Completely dark is when CRT makes its move on you though
| Posted: Fri Apr 19, 2013 5:48 am Post subject: |
| Jeremy112 wrote: | Even at 720p, or at 1366x768 (which is what I use for a PC to the NEC XG) CRT can blow away 1080p, just for the pure smoothness of the image while moving. The colors, the REAL contrast ratio, man it makes me want a G90 all over again!
Completely dark is when CRT makes its move on you though  |
Don't forget the "CRT walk" in total darkness when you get up for a drink refill or to get rid of that last drink and the picture fades to black it's black! You pause until the screen lights up again.
If you want to have ambient light I'd suggest a halogen dimmable lamp with a recessed socket. It puts light where you need it and doesn't hit the screen as much as a regular lamp on in the room.
| Posted: Fri Apr 19, 2013 9:48 am Post subject: |
This is why I drink my drinks in a 1ltr stainless steel milkshake cup... Stays colder longer too
Use the torch app on your phone!!
How come you don't use 1600x1200 on that XG? Or even 1680x1050?
Brennithechamp
| Posted: Fri Apr 19, 2013 12:05 pm Post subject: |
| Curt Palme wrote: | REad this:
Overall, a DLP will look sharper, but the CRT will look more natural by far. |
He's asking for $200 for it, it looks in okay condition though. Things in canada tend to run a little more expensive (No idea if that transferes over to projectors though). I don't know if It's breaking forum rules to post the ad so if I am just let me know!
Here's the ad http://ottawa.kijiji.ca/c-buy-and-sell-electronics-Barco-708s-crt-projector-excellent-condition-W0QQAdIdZ469467817
| Posted: Fri Apr 19, 2013 12:33 pm Post subject: |
Need to see tube faces, and that has none.
The projector is worth more if the tubes rate good. If they had wear from being installed too far back, they aint worth dik.
You could probably find an NEC for that price, and itll be a much more capable projector, being EM focus, having better convergence etc......
| Posted: Fri Apr 19, 2013 1:15 pm Post subject: |
Yeah, the outside case says nothing as to the condition of the tubes. He might not let you take off the lenses, so if nothing else, shine an LED flashlight through the lenses with the set off, and compare the tube faces to this:
http://curtpalme.com/TubeCondition_RatingChart.shtm
Keep in mind that the lenses will mask tube wear, so if you see an '8' condition, it's more likely a 6 or so with the lenses off.
Tubes are no longer available, and were $700 each when new, so unless you find mint used tubes (I have a couple), replacement tubes are going to be more than what you paid for the set. Make sure he has the remote for it as well, they are also expensive.
You can usually get a decent pix out of a set with a bit of tube wear, it just won't be perfect. If it has tube wear and no remote, then the set is overpriced. It's a buyer's market right now, so offer $100 and see what happens.
Brennithechamp
| Posted: Fri Apr 19, 2013 1:21 pm Post subject: |
Guaranteed that's tube wear. XG tubes are harder to find than 708 tubes!
But see, look hard enough, and they're everywhere. 99% of my sets come up from the US, so check Detroit as well if you go into the US...
Brennithechamp
| Posted: Fri Apr 19, 2013 2:23 pm Post subject: |
Do you think the tube wear will be a big issue? It says 4500 hours use, how much are they rated for? Also states isn't an option unfortunately just cause the border is a big hassle, although shipping might work!
kal Forum Administrator
| Posted: Fri Apr 19, 2013 2:26 pm Post subject: |
| Brennithechamp wrote: | | Do you think the tube wear will be a big issue? It says 4500 hours use, how much are they rated for? Also states isn't an option unfortunately just cause the border is a big hassle, although shipping might work! |
The border is easy. I've brought CRT's with me in and out of the US. I took my SONY 1252 on vacation to Newfoundland back in 2006 via the US.
It helps when crossing the border if you have a receipt. Though most of the time I just tell them how much I spent and it's good.
That being said I've bought many projectors and parts off Kijiji locally too.
| Posted: Fri Apr 19, 2013 2:31 pm Post subject: |
Brenn, tube wear is like trying to judge a car engine. If driven/set up properly, they will last 8000-10,000 hours, sometimes even more. Problem is, the NEC tubes wear very quickly, and NEC was conservative with running to the tube face edge, so they wear more quickly than other sets typically. Same with the later model Sonys. Based on the description, you can safely think that the G and B tubes are going to be toast, making the set worthless.
Still, it's a higher end set than the 708, but unless you want to spend $500-1000 on a mint set of XG tubes (I have one set here), you won't find tubes for the XG.
Jeremy112
| Posted: Fri Apr 19, 2013 2:33 pm Post subject: |
| CasetheCorvetteman wrote: | This is why I drink my drinks in a 1ltr stainless steel milkshake cup... Stays colder longer too
How come you don't use 1600x1200 on that XG? Or even 1680x1050? |
I'm not a 4:3 type of person really. at 1680x1050 was a bit soft on my XG when I did use it. Besides 768p works wonders on the XG, the lettering on a PC signal is damn near razor sharp with only the faintest of soft edges (probably the haloing effect with AC lenses)
| Posted: Fri Apr 19, 2013 3:12 pm Post subject: |
As Curt said the tube life is highly depending on how it is used.
Look at this:
This 6PG xtra ran less than 2600hrs, and none of the tubes are usable.
On the other hand this is my 6PG xtra:
It has more than 4000hrs in it.
Jeremy: Have you tried the 1600x900@72Hz? It looks great on my 6PG xtra!
| Description: |
| Filesize: |
79.54 KB |
| Viewed: |
6221 Time(s) |
