Jeremy112
| Posted: Sun Mar 24, 2013 1:30 pm Post subject: |
You probably won't find any parts for this unit anywhere besides Denon, or you could wait until one hits ebay as parts or repair. Just remember that if you are buying used parts, depending on what exactly you are replacing, if the replacements are from an MK1 that could affect performance. If you are only doing the amplifiers/power supply, then you are probably safe to use MK1 components.
an MK2 will cost you $2000 or so used working, MK1 at best $1000, so if you do find the parts, just make sure you don't spend more than its worth to repair, unless you feel its worth it. I think you would be best suited to take the receiver and send it to a Denon authorized service station if it does need repair, these receivers aren't for the faint of heart, one of the parts units I bought to repair the other one was so mangled from someones piss poor attempt to repair it, that's why it wound up on ebay. The guy managed to screw it up to the point he couldn't repair it himself.
Just a few tips, I want to make sure you have a good repair experience
