No clipping at all
jeffslife
Posted: Mon Mar 11, 2013 9:48 pm    Post subject: No clipping at all
I needed the space so I decided to incorporate my music room into my HT. I changed the entire audio set up. I am now using my yamaha m80 to drive the front speakers, The Integra is only driving the center channel speakers. My Kenwood is driving the rear surrounds and I have a separate amp for the subs,(2) Plus one that is self powered. I decided to use the Crown XLS 202 to drive the surrounds.(Polk rti a9's which I bi-wired).
I can turn the gain up all the way on the polks and run it in stereo and the clipping lights never even flicker. When I was driving the front channels with the crown before I changed it over I could only run the gains at about 70% before the clipping lights would start to flicker. I reset all the levels tweaked it all for maximum soundstage and it never clips.At all. Even at full volume in stereo. I am not complaining,just confused.
P.S. I DO hear a difference in bi-wiring, I cant figure out why but its there.
We are ALL job creators !
Posted: Thu Mar 14, 2013 4:15 pm    Post subject: Re: No clipping at all
jeffslife wrote:
I am now using my yamaha m80 to drive the front speakers, When I was driving the front channels with the crown before I changed it over I could only run the gains at about 70% before the clipping lights would start to flicker.
simple, the Yamaha has bigger balls than the Crown Laughing
No way, your delusional, crazy, a complete nut job. There's no way wiring can change the sound of an audio system. Wink
If your Polk's were a little muddy or lacking in detail, bi-wiring should have helped that.
jeffslife
Posted: Thu Mar 14, 2013 4:53 pm    Post subject:
OK on the bi-wiring thing, I hooked them up A B to the Adcom speaker switcher I have and had 3 people listen. All 3 preferred the bi wire set up. There IS a difference.
dturco
Posted: Thu Mar 14, 2013 5:30 pm    Post subject:
jeffslife wrote:
OK on the bi-wiring thing, There IS a difference.
You're Damn skippy there is Thumbs Up
http://www.hulu.com/firefly
