dluck
| Posted: Wed Mar 06, 2013 11:36 pm Post subject: runco vx-1000ci, component to rgb converter, can I use it? |
I have an NEC XG135 that has rgb input. I've found a vx-1000ci control box that has component in and rgb out. Can I use it to convert component to rgb/ The owner says you need to setup the serial cables and have it programmed. He's asking $199 for it.
thanks.
dluck
| Posted: Thu Mar 07, 2013 2:07 am Post subject: |
I already have a key digital color space converter I bought around 2005.
The NEC doesn't have much for scaling (just line doubling), (nor do these colorspace converters from what I can tell). From what I've been reading the VX-1000ci can do some nice hv scaling. Am I comparing apples to apples? The one you suggested does look nice.
| Posted: Thu Mar 07, 2013 9:02 am Post subject: |
| dluck wrote: | I already have a key digital color space converter I bought around 2005.
The NEC doesn't have much for scaling (just line doubling), (nor do these colorspace converters from what I can tell). From what I've been reading the VX-1000ci can do some nice hv scaling. Am I comparing apples to apples? The one you suggested does look nice. |
The RTC2200 is a component to RGBHV converter with an adjustable low end gamma bump. It's a good economical solution to get a YPbPr /component signal into the projector. You can also run RGBHV sources through the VGA input so if you want to connect a laptop or PC to the projector it makes a convenient place to plug it in, and you get the gamma on that input as well.
If you want much more control follow Nash's advice and go for a scaler and an external Moome box.
What sources will you be using with the projector?
EDIT: Looks like the vx-1000ci scales everything to 1280x720. I'm not sure the digital video timing for the original DLP projector will play nicely with your NEC 135.
