using moome card......
digitalayon
Posted: Mon Feb 18, 2013 3:32 am    Post subject: using moome card......
I know the moome card will not convert the 1080p 24 to a higher refresh rate(should have bought the FURY4) but what is my CHEAPEST option to get 1080p 24 converted to 60 HZ for the Moome card in the 9500?
Posted: Mon Feb 18, 2013 3:43 am    Post subject:
An older Lumagen HDP or HDQ. Keep a look out.
digitalayon
Posted: Mon Feb 18, 2013 7:24 am    Post subject:
yeah that might be too long of a wait.....can get the whole FURY4 package for 500 bucks
kabuby77
Posted: Mon Feb 18, 2013 9:56 am    Post subject: Re: using moome card......
You can disable 24p from your blu-ray player , then it will convert 24p to 60p. Otherwise you can try the same thing with the AV receiver.
Posted: Mon Feb 18, 2013 3:08 pm    Post subject: Re: using moome card......
+1. All sources that support 24p Blu-ray let you turn off 24p. Nothing special is required. What is the source?
Posted: Mon Feb 18, 2013 3:15 pm    Post subject: Re: using moome card......
Unless its the LG BH100. it only has 1080p@24.
Posted: Mon Feb 18, 2013 3:32 pm    Post subject:
Ah - good point. I forgot there are some oddballs out there that do not allow 24p to be turned off. Either way, it would be much cheaper to buy a $50-100 Blu-ray player that does allow 24p to be turned off than buying a video processor.
digitalayon
Posted: Tue Feb 19, 2013 2:59 am    Post subject:
Kal, I agree.....Direct TV does not offer the option.
digitalayon
Posted: Tue Feb 19, 2013 3:03 am    Post subject: Re: using moome card......
At what cost? And what are my guarantees it will work? Which models?
Does Direct TV offer 24p? I didn't think it did. I don't see how they could. Only films are shot in 24fps. Most TV shows and commercials are 30 fps. It would be constantly switching back and forth (with a pause from your display - very annoying) if they were to actually allow movies to be shown at 24 fps on Direct TV.
24p is (generally speaking) a Blu-ray only thing.
Posted: Tue Feb 19, 2013 3:31 am    Post subject:
DirecTV does indeed support 1080p/24, but only on PPV movies. They actually encode and broadcast those channels in 1080p/24, then add 3:2 pull-down in the STB (if 1080p isnt enabled) just like a BD player does. Unlike BD, DTV boxes don't output 1080p/30; only 1080i/60 or 1080p/24 (and 720p and 480p, of course).
Posted: Tue Feb 19, 2013 3:36 am    Post subject:
Dishnetwork also does 1080p@24 since 2008 I think.
Posted: Tue Feb 19, 2013 3:37 am    Post subject:
This would have been easier than writing all that.
http://support.directv.com/app/answers/detail/a_id/1398/~/1080p-on-directv
Posted: Tue Feb 19, 2013 3:43 am    Post subject:
There is a lumagen HDP for sale here
http://cgi.videogon.com/cgi-bin/cl.pl?procscal&1355336965&&&/Lumagen-HDP
120 bucks!!!! A must for CRT, calibration of Greyscale at 11 points and gamma. Also has limited CMS, primaries but no secondaries.
I's jump on it if I were you.
Posted: Tue Feb 19, 2013 4:51 am    Post subject:
Thanks for the clarification. Only doing it on PPV makes sense. Otherwise the switching would drive someone nuts.
I'm surprised that they don't allow a 60hz output option however! Odd.
As Nashou points out - there is a lot more you can do with a video processor than just 24 -> 60Hz conversion....
