Electrohome Marque Convergence
dang
Posted: Mon Feb 11, 2013 12:31 am    Post subject: Electrohome Marque Convergence
I recently acquired an Electrohome Marque 8110 Plus through craigslist. The projector works fine and after making all the adjustments it has a great picture. My problem with it is that I can't get it to save the convergence settings. After going through the convergence proceedure and saving the settings, the picture looks fine, until I turn off the projector. Then next time I view it, the convergence is off an needs to be done again. This isn't true for the picture geometry settings or the brightness or contrast. All these settings can be saved successfully and don't need to be reentered each time the machine has been turned off. Am I missing something and doing this wrong, or is there something wrong with the convergence memory? Thanks for any help you could send my way.
Dan Gilroy
Posted: Mon Feb 11, 2013 12:33 am    Post subject:
Utilities>source set up>unlock or lock. Unlock the memory then do the convergence, after your done lock it again.
Posted: Mon Feb 11, 2013 11:47 am    Post subject:
Hello
Also, make sure ASR is switched OFF
dang
Posted: Mon Feb 11, 2013 4:09 pm    Post subject:
Thank you both for that info. My memory was locked and the ASR was on. I'll try again tonight. Tim what is the ASR anyway? Thanks
Dan Gilroy
Posted: Mon Feb 11, 2013 4:59 pm    Post subject:
Automatic source recall, it would be cool if it actually worked : )
Posted: Mon Feb 11, 2013 6:17 pm    Post subject:
Hello
ASR means "Auto Source Recall" and it will take an average of other settings when a new signal is detected; but that average-of-settings memory cannot be adjusted and saved automatically.
