ScottJ
Joined: 24 Jan 2013 Posts: 11 Location: San Francisco, CA
| Posted: Thu Jan 24, 2013 1:30 am Post subject: Use one Radiance with two displays? |
I will soon have both a plasma and a projector, though I will only use one at a time. Is it possible to use a single Radiance unit on both, and switch between two different setups based on which display is currently in use?
ScottJ
| Posted: Thu Jan 24, 2013 3:11 am Post subject: |
| Nashou66 wrote: | Yes, they have dual out puts but you'll have to do a different Calibration memory for each display. So you might calibrate your Plasma to output config 0 and send that to output 1, then make a different output config 1 and send that to output 2.
Please clarify; I can set each output to a unique calibration config, and then leave it that way? No need to touch the Lumagen (or send any IR commands to it) when I switch displays?
What if I get the mini, which has only one output, and a downstream HDMI splitter like this?
| Posted: Thu Jan 24, 2013 4:17 am Post subject: |
| ScottJ wrote: | | Nashou66 wrote: | Yes, they have dual out puts but you'll have to do a different Calibration memory for each display. So you might calibrate your Plasma to output config 0 and send that to output 1, then make a different output config 1 and send that to output 2.
What if I get the mini, which has only one output, and a downstream HDMI splitter like this? |
You'll have to switch memories on the Lumagen when you switch displays.
You can use a Mini on an HDMI splitter for two displays. It would be better to use an XS or EX though.
