studio
| Posted: Tue Jan 22, 2013 12:08 am Post subject: fury 3 green output only |
Friend borrowed 3 I switched back to 2 temporary working fine. I unhooked 3 from friends setup came home to replace 2 but now only getting green output from pj. Any ideas??
| Posted: Tue Jan 22, 2013 12:10 am Post subject: |
Set output to RGB on HDFury3?
studio
| Posted: Tue Jan 22, 2013 12:15 am Post subject: |
Tried this with all 5 bnc's connectes
| Posted: Tue Jan 22, 2013 1:48 am Post subject: |
What are your dip switch settings? DIP 1 should be switched to ON for RGB output.
| Posted: Tue Jan 22, 2013 1:05 pm Post subject: |
That is what its most likely gonna be, its set to component output.
studio
| Posted: Thu Jan 24, 2013 3:14 am Post subject: |
I did switch to RGB. It like the output is not strong enough to drive the Barco1209s I switched 5 off it helped to keep the pj from going in and out of black, but the level is way off?? I can go back to the 2 and its fine?? Need help.
| Posted: Thu Jan 24, 2013 3:24 am Post subject: |
Try connecting the R G and B outputs to a component input of a flat screen TV. If that shows good color.. the Fury is still somehow in component output mode. Component is not the same as RGBHV.
studio
| Posted: Thu Jan 24, 2013 3:27 am Post subject: |
It's crazy unhooked it and connected again and it works???
| Posted: Thu Jan 24, 2013 3:50 am Post subject: |
| studio wrote: | | It's crazy unhooked it and connected again and it works??? |
How long is your HDMI cable?
studio
| Posted: Thu Jan 24, 2013 3:51 am Post subject: |
25ft
| Posted: Thu Jan 24, 2013 4:01 am Post subject: |
That should be fine. Lately with HDMI in general we've seen short cables ( less than 3 feet ) cause problems.
As to unhooking it and plugging it back in. Welcome to the flakyness that's HDMI.
I've seen that with PC video cards, DVD recorders, HDMI switchers, PS3's and Bluray players.
Phoenixed
| Posted: Thu Jan 24, 2013 4:07 am Post subject: |
Good ole hdcp.
| Posted: Fri Jan 25, 2013 12:03 am Post subject: |
Have you got the power supply connected to the Fury 3? 5v at least 1A?
Sorry if thats been posted im using a phone at the moment.
