HK-Steve
| Posted: Sat Dec 22, 2012 6:32 pm Post subject: RS232 pinout for Marquee 9500 |
Hi Guy's,
Looking for the RS232 pinout for my AMX control of my Marquee,
From my quick look, stress, QUICK, 2,3,&5 are the pins I need.
Can anyone also confirm, please.
Cheers
| Posted: Sat Dec 22, 2012 11:11 pm Post subject: |
Hey Steve
2 is Rx, 3 is Tx, 5 is Ground at the Marquee.
HK-Steve
| Posted: Sun Dec 23, 2012 8:23 am Post subject: |
Thanks Tim,
Are you sure of the Rx and TX, I do trust your Marquee knowledge,
I checked the schematics of the CLM, and looked like they were the other way around.
Googled it, got your answer, schematics are the opposite.
Anyone else comment,
Cheers
| Posted: Sun Dec 23, 2012 11:52 am Post subject: |
Not sure what you're asking. RS232 is either straight or null. Null is reversed (see image below).
So it shouldn't matter what the pin-out is, it should simply be rather it's "null" or "straight" if you're going from DB9 to DB9 connection.
| Description: |
| Filesize: |
10.01 KB |
| Viewed: |
6264 Time(s) |
barclay66
| Posted: Sun Dec 23, 2012 1:42 pm Post subject: |
Serial cables for the Marquee should be straight (DB9 pins: 2 - 2, 3 - 3, 5 - 5). Just built a new one last week as I needed a longer one after mounting the PJ on the ceiling...
Regards,
barclay66
HK-Steve
| Posted: Sun Dec 23, 2012 2:38 pm Post subject: |
It is RS232 from my NI3100 AMX controller to the Marquee.
Just trying to be sure before I solder the plugs and tidy all the cable, just do not want to redo it again.
Cheers
dvh99
