freidich
Joined: 15 Oct 2012 Posts: 54 Location: Philadelphia, PA & Providence, RI
| Posted: Sat Dec 22, 2012 2:38 am Post subject: screens for crt |
What are the characteristics of a good screen for CRT's? Other than a gain <1.3, is there anything I should know? Is it possible to judge the quality of a used screen on craigslist in person? And what are the best brands/reasonable prices to spend on such a screen? Thanks again guys.
freidich
| Posted: Sat Dec 22, 2012 2:54 am Post subject: |
I haven't really determined a budget and anything from 80" to 200" for a screen. I was more interested in seeing how much x dollars gets you vs 2x vs 4x, etc. Also if I were to find a high-quality used screen, is it possible to see flaws in it without watching a movie on it or spending a lot of time? And I have no problems with building the frame if it saves a lot of money, but if the price is comparable, a complete solution is preferred.
Phoenixed
| Posted: Sat Dec 22, 2012 3:16 am Post subject: |
I made mine from Wilson Art (~1.5gain) after using a Jamestown screen. Jamestown was around $250 and he uses SMX Centerstage (~1.0gain) material which is acoustically transparent. Both are 100"
freidich
| Posted: Mon Jan 14, 2013 7:06 am Post subject: |
Are any of the Stewart or Da-lite screen materials particularly good or particularly bad for CRT's? Also, thoughts on manual and electronic pull down screens? I understand that the screen is more prone to wrinkles, but is this less of an issue with high end screens from Stewart or Da-lite?
freidich
HaydnG90
| Posted: Mon Jan 14, 2013 5:13 pm Post subject: |
If cost was not an issue I'd order Stewart Studiotek 130 G3 screen material. Its finer grained than the original ST 130 formulation. I tried Videomatte 200 but experienced significant 'sparklies' with the G90 to the point that it was unacceptable. If you have total light control try the ST130.
If you are floor mounting the projector take a serious look at the Dalite HP. Very little hotspotting which is often the achiles heal of high gain screens. For the performance its a fantastic bargain.
KellenerSptM5
| Posted: Mon Jan 14, 2013 11:15 pm Post subject: |
I used Seymour AV's Center Stage XD and had really good results. It's a acoustically transparent screen, not sure if you want or need that. They sell it by the foot for DIY, I believe I dealt with a guy by the name of Chris when I ordered my material. He was very helpful.
| Posted: Mon Jan 14, 2013 11:34 pm Post subject: |
| KellenerSptM5 wrote: | | They sell it by the foot for DIY, I believe I dealt with a guy by the name of Chris when I ordered my material. He was very helpful. |
That would be Chris Seymour, as in the owner. He's a great guy and an enthusiast. He's very knowledgeable, and even though he's certainly catering to professionals in the CEDIA channel, he's very supportive of the DIY community. He's come to a few of our Iowa get-togethers, and I always enjoying chatting with him.
KellenerSptM5
| Posted: Mon Jan 14, 2013 11:51 pm Post subject: |
| ecrabb wrote: | | KellenerSptM5 wrote: | | They sell it by the foot for DIY, I believe I dealt with a guy by the name of Chris when I ordered my material. He was very helpful. |
SC |
He certainly left me with a very good impression of him, he took the time to work with me to figure out the proper size and everything for me to DIY a screen with his material. I definitely will be purchasing my next screen through him.
Phoenixed
| Posted: Tue Jan 15, 2013 2:58 am Post subject: |
Centerstage is awesome stuff. Specially for the DIYer.
| Posted: Tue Jan 15, 2013 3:44 am Post subject: |
I am thinking of going with HP for my floor mount CRT. It would make it easier when I switch to digital to shelf mount the pj.
LOTREE
Joined: 19 Mar 2006 Posts: 401 Location: Paradise, Newfoundland
| Posted: Thu Jan 17, 2013 2:17 am Post subject: |
I'll second the WilsonArt, durable, scrubbable, washable. Completely satisfied with mine. I paid $94 for 49" width x 8'. An aluminium U channel frame can be built for around $70-$80 or less, depending on the price of material in your area. L brackets, bolts, lock nuts and a long roll of velcro and you're set. A laminate trimmer or router with laminate bit is required though.
_________________ Zenith Pro 1200x | Electrohome ECP 4500 | Yamaha HTR-5740 | HTPC & Speaker build to follow
Ile
| Posted: Thu Jan 17, 2013 1:07 pm Post subject: |
Been used Draper M1300 material (framed diy) and Stewart studiotek 130 (tab-tensioned roll down) in previous systems.
My current screen is diy laminate screen and it's so close to those much higher priced screen materials, that there's no reason to go back.
Laminates around 1.3 gain is bit high for my taste (like studiotek), so color sift bothers around IRE90-100 area. There guite few movies with long full white fields, so it's not real problem.
M1300 was more like 1.2 gain. I really liked that material alot, but wanted bigger screen and went with laminate.
