Drexler
Joined: 21 Dec 2012 Posts: 2 Location: Copenhagen, Denmark
| Posted: Fri Dec 21, 2012 7:56 am Post subject: Pre-calibration settings before autocal |
I hope someone could give some advice regarding the autocal feature (my setup is: Display 3 pro, lumagen mini, chromapure 125p, Sony VW85 750h). I have tried playing with it but don't get the perfect result I was hoping for.
I started with an oversaturated gamut (mostly color saturation that was too high). However, the lumagen could only reign in the colours ever so slightly. Shouldn't it be able to get them all the way in? I can't get them all good using the internal tools. I have to choose, either saturation (high) or luminance is off in green and cyan.
How do you pre-calibrate the grey scale? As good as you can before hand creating a compromise between top/mid/bottom, or aiming at either getting the very high or low end near perfect?
I tried it twice, once in 10 and once in 5% increments. The 10% was OK, but still a bit off in the low end. The 5% measured quite good but the colour was visibly far off close to black with a very obvious green tint. I guess it doesn't measure close to black and the 5% adjustments completely threw the lower levels off?
Any other suggestions or tricks?
Any help would be really appreciated! I don't have as much time as I would like to experiment and it really takes a long time doing these pre-autocal calibrations...
Thanks!
Ted
kal Forum Administrator
| Posted: Mon Jul 01, 2013 12:48 pm Post subject: Re: Pre-calibration settings before autocal |
| Drexler wrote: | | Any help would be really appreciated! I don't have as much time as I would like to experiment and it really takes a long time doing these pre-autocal calibrations... |
All you have to do is put the display into the best Picture preset and set brightness, contrast, and sharpness. These can only be set visually. It takes a few minutes.
stridsvognen Guest
| Posted: Mon Jul 01, 2013 2:32 pm Post subject: |
I like to balance the grayscale, measured at 5% and 100% before starting to use the radiance, And you whave to find the color profile in your projector whos closest to REC 709, but it have to be a bit oversaturated.
If you use a very oversaturated color profile you will get more color banding.
Also be sure you have the latest Radiance firmware.
