Will Lumagen Vision HDP pass HDaudio?
This forum is locked: you cannot post, reply to, or edit topics.   This topic is locked: you cannot edit posts or make replies.    CurtPalme.com Forum Index -> Lumagen Products
Gerbrand
Posted: Tue Dec 11, 2012 9:33 am    Post subject: Will Lumagen Vision HDP pass HDaudio?
Hello,
I am considering buying a UMC-200 surround processor from Emotiva. This processor only has one HDMI output and 4 inputs.
I am using both a HTPC (one HDMI output) and a Oppo BDP-83 Bluray player (one HDMI output) as sources..
The set-up I was considering is:
HTPC->UMC-200->HDFury3->projector (BG1209s)
Blu-ray player ->Lumagen HDP->UMC-200->HDFury3->projector
Since the Lumagen cannot be used with the HTPC (it will not pass 1080p60), putting the scaler behind the UMC is not an option.
My current set-up is:
HTPC->HDFury 3->projector
Oppo->Lumagen->HDfury3->projector
So the big question is:
In my suggested set-up, will the Lumagen pass the HDAudio signal on to the UMC processor? If not do you have other solutions.
Regards,
Gerbrand
BG1209s (color filtered,new LUGs!), 13000h
Bat cave
Posted: Tue Dec 11, 2012 1:20 pm    Post subject:
No it doesn't. Get a HDMI spitter.
This forum is locked: you cannot post, reply to, or edit topics.   This topic is locked: you cannot edit posts or make replies.    CurtPalme.com Forum Index -> Lumagen Products All times are GMT
