rodmonkey
| Posted: Sat Nov 24, 2012 10:12 pm Post subject: Runco 991 woes - CRTs not coming on |
I've had my 991 (NEC XG75) for about 15 years, and recently, when I turned it on, it seemed to power up (the fan came on, and I heard the high-voltage sizzle), but the CRTs don't come on at all. In addition, while remote "on" works, the unit won't respond to remote "off" or any other button - it has to be powered off by the power switch on the front of the unit. No error code, unless 00 counts.
The unit did come up for a short time for a day, long enough to see that the red gun wasn't aligned correctly, but since then, nada.
Any ideas on what I can do to diagnose this further?
Rod
| Posted: Sat Nov 24, 2012 10:38 pm Post subject: |
Really, rodmonkey was the best user name you could come up with?
Take a look into the lenses with a flash light just to be sure you don't have a broken tube.....
| Posted: Sat Nov 24, 2012 11:50 pm Post subject: |
This could be a system board issue. COuld be a snapped neck on a tube, but with the remote not working, I'd suspect the system board. That's in the card cage under the cover, and it slides out easily to be sent to me for testing and repair. PM me and we can discuss further. Also throw your location in your profile, it will help if you need assistance.
Welcome.!
| Posted: Sun Nov 25, 2012 3:32 am Post subject: |
My 991 wouldnt respond to the remote after it was turned on when there was a HV board issue. It varied from a squeal and no HV to turning off on its own with no code, to turning off with a code, then back to normal. Hasnt done it since.
I pulled all the boards out at the back and cleaned the connectors, and all the ones on the HV board and its partner beside it, never done it again.
Never know your luck
rodmonkey
| Posted: Sun Nov 25, 2012 7:23 pm Post subject: |
| Curt Palme wrote: | | This could be a system board issue. COuld be a snapped neck on a tube, but with the remote not working, I'd suspect the system board. That's in the card cage under the cover, and it slides out easily to be sent to me for testing and repair. PM me and we can discuss further. Also throw your location in your profile, it will help if you need assistance.! |
Whoops! Too few posts, so PM'ing is disabled for me!
I assume this is the board on the hinged cage that drops down?
R
rodmonkey
| Posted: Sun Nov 25, 2012 7:25 pm Post subject: |
| CasetheCorvetteman wrote: | My 991 wouldnt respond to the remote after it was turned on when there was a HV board issue. It varied from a squeal and no HV to turning off on its own with no code, to turning off with a code, then back to normal. Hasnt done it since.
Never know your luck  |
Since there's a possibility that I'll end up send the board to Curt anyway, definitely worth a try. Thanks!
Rod
| Posted: Sun Nov 25, 2012 7:41 pm Post subject: |
Yes, there's a white sticker under the cover that indicates which one it is. It's the one that the back LED and buttons connect to. Post twice more in this thread, and you can PM me. Or email me at curtpalme at shaw.ca.
rodmonkey
| Posted: Sun Nov 25, 2012 11:41 pm Post subject: |
4...
rodmonkey
| Posted: Sun Nov 25, 2012 11:43 pm Post subject: |
4 1/2... (double posted - poo)
rodmonkey
5.
| Posted: Sun Nov 25, 2012 11:44 pm Post subject: |
That was a bonus 4, now you can send me a PM !
