fefrank
| Posted: Wed Oct 31, 2012 2:22 pm Post subject: HD-145'S and 1080P |
This is not clear to me. I keep reading and hearing that A machine let's say a BG1208s has HD8's but HD8's are not capable of resolving 1080P? but Hd-145 lenses are? What is the difference? I thought that the projector tubes were the ones who resolve resolutions. So how would a 8500 Marquee with HD-145 lenses resolve full HD but not with HD-8's? This is a topic that was discussed in one og the threads I found around. Can someone explain this to me?
virusc
Joined: 11 Apr 2007 Posts: 358 Location: Massachusetts
| Posted: Wed Oct 31, 2012 2:34 pm Post subject: |
the problem is HD-8's are not that good of a lense especially at the edges. HD-145s when used in the sweet spot screen size range (can't remember exactly right now) are in fact much sharper and have better contrast due to the lense containing more glass elements or just being better engineered. However, their can be issues if you run you raster very large or the lenses are close to the crt faceplate or both. This is why HD-8's were used more often.
| Posted: Wed Oct 31, 2012 2:55 pm Post subject: |
Think of it like this: The CRT's are the retina; the lens is the cornea. If the cornea sucks, it doesn't matter how great the retina is.
The fact is that most HD-8 lenses were engineered and manufactured for CRT projectors when signals like 480p and 600p were the dominant resolutions.
There are also apparently variants of the HD-8. The HD-8's that were on Sony 12xx sucked ass. The tubes in 12xx's were MUCH higher resolution than the lenses, easily resolving 1080i scan lines on the phosphor, while the lenses resolved something less than half that (scan lines were invisible).
Apparently, the HD-8's on 8500's were much better than what shipped on the Sonys. I always wanted to try a set of 144/145's, but Joust's mods cost as much as my projectors. I moved on to LC before the itch ever got strong enough.
ElTopo
| Posted: Wed Oct 31, 2012 3:09 pm Post subject: |
If you use P16 high rez tubes (8 inch) with HD-145 you get a very good picture on your screen.
ElTopo
digitalayon
| Posted: Wed Oct 31, 2012 5:20 pm Post subject: |
Felix, I am not sure if lens really matters in terms of 1080p. A HDFury will make so so you can set it at a lower resolution if you need but will not lose anything in terms of detail. The lens swap will assist with corner focus and color filtering.
fefrank
| Posted: Wed Oct 31, 2012 5:54 pm Post subject: |
When I fired up the 1208s I thought that 1080p looked great even with the Standard HD8's. I do have to say that 720p looked sharper. I saw the screenshots of joust's projector with hd-145 lenses. Was that a marquee 8500 he was using? if that was an 8500 that was a very sharp picture for being 180DVB22 tubes, unless he was using other tubes in the projector or it was an LC. does anyone know? I am just like the kids who want to peek into their christmas presents before christmas day comes around.
All I know is that corner focus on hd8's is extremely horrible. I can't get it to focus a 16:9 Screen on the edges or corners. It's kind of sad. the middle does great though. I like the way ecrabb explained that by the way. It makes more sense to me now.
I am planning on using my HTPC for this instead of a bluray player with a moome or an hdfury. VGA to RGBHV. It's that a downside? Would I get better PQ with this setting:
Bluray Player>--HDMI>---Moome Box (HDFury)>---VGA to RGBHV Cable>--- Projector
I am currently using:
HTPC>----VGA to RGBHV cable>---- Projector
What are your thoughts on that doing 1080p which one will give me a cleaner picture?
| Posted: Wed Oct 31, 2012 6:56 pm Post subject: |
You'll get varying opinions on this, but I always much preferred 1080i to 720p. It makes no sense to me to throw away a bunch of picture detail digitally so that the projector will resolve it better. Great! You now have a perfectly resolved (inferior) picture! But, like I said, everybody has a different opinion on this. I also like it better because I didn't use an HTPC, so I was running 1080i/60, which gives you smoother 24p playback than does 720p 60.
If you're going to use an HTPC, then it solves the frame rate issue. First of all, you can run 71.928Hz or 47.952 if you like and not worry about interlacing.
For a computer desktop display, you do care about fully resolving, because if you don't, it can make the desktop icons, text, menus, etc. hard to read. In that case, you probably do want to do something like 720p.
What you might want to do is play with something like the Nokia monitor test app at some different resolutions. Turn off R and B and don't even worry about convergence... Just try some different resolutions between 1080p and 720p and see what's the best tradeoff between sharpness and resolution. Perhaps 1440x810, or 1600x900 might be the ticket.
Regarding corner focus... How close are you running the corners to the edge of the tube face. The closer those corners are, more trouble you'll have focusing them. A lot of guys here chase maximizing their rasters so hard, they completely screw up any semblance of corner focus ability. Of course, you can rationalize that because A) you're not usually looking at a desktop, and B) you're not usually looking at the corners.
As for STB vs. HTPC picture quality, they should be very similar, with the caveat that you get much more flexibility with the HTPC on signal resolution, refresh rate, etc., but also more hassle, too.
digitalayon
| Posted: Wed Oct 31, 2012 8:43 pm Post subject: |
Hey Felix....I think Crabbs LCOS has our stuff in it.
fefrank
| Posted: Thu Nov 01, 2012 12:40 pm Post subject: |
It definetly has. I just made some parts for JVC not too long ago. They were interesting and Really expensive!!! by the way.
| Posted: Thu Nov 01, 2012 4:13 pm Post subject: |
| digitalayon wrote: | | Hey Felix....I think Crabbs LCOS has our stuff in it. |
| fefrank wrote: | | It definetly has. I just made some parts for JVC not too long ago. They were interesting and Really expensive!!! by the way. |
OK, you can't just drop some comments like this and not keep going! I want to hear more about this! Can you spill any beans, or if you tell me, will you have to kill me?
fefrank
| Posted: Thu Nov 01, 2012 6:35 pm Post subject: |
We work for a company that makes polarizers for most digital projector companies in the market. Mostly for LCOS and LCD's. I probably made the one inside your projector! , depending on when you bought it, since it is a JVC RS45, each Lcos panel has a polarizer to help with contrast and color. so you would have 3 polarizers in there, one per panel (Green, Blue, and Red).
| Posted: Thu Nov 01, 2012 6:50 pm Post subject: |
Very cool! I've never seen the JVC's torn down... Are the polarizers glass in these machines?
digitalayon
| Posted: Thu Nov 01, 2012 11:40 pm Post subject: |
Sort of in the glass moreless.....there are several steps and process's in making what we call the "wafer". All done in clean rooms and very very expensive to make!! Felix is our post fab guy. I just handle the IT end.
fefrank
| Posted: Fri Nov 02, 2012 12:48 pm Post subject: |
| ecrabb wrote: | Very cool! I've never seen the JVC's torn down... Are the polarizers glass in these machines?
SC |
It really depends on the projector and the applications. Glass is mostly used for high temperature applications. I am positive that your JVC projector has a glass polarizer in it just because is used for contrast and visual light. If it's not completely glass It would still be glass but mixed with other components. Organic polarizers (plastic. thick paper mesh ect.) are too delicate for a machine that gets that hot. You could get lots of issues with organic polarizers, that's why the industry now is going inorganic. You get more efficiency, a better picture and much better durabilty, and even in extreme temperatures you get much better performance.
digitalayon
| Posted: Fri Nov 02, 2012 8:43 pm Post subject: |
| Quote: | | It really depends on the projector and the applications. Glass is mostly used for high temperature applications. I am positive that your JVC projector has a glass polarizer in it just because is used for contrast and visual light. If it's not completely glass It would still be glass but mixed with other components. Organic polarizers (plastic. thick paper mesh ect.) are too delicate for a machine that gets that hot. You could get lots of issues with organic polarizers, that's why the industry now is going inorganic. You get more efficiency, a better picture and much better durabilty, and even in extreme temperatures you get much better performance. |
Well....I guess I should get to know our products better!!!! I got to know JFETS last week.
| Posted: Fri Nov 02, 2012 8:51 pm Post subject: |
Thanks, guys! Cool stuff.
I'd love to see a JVC torn apart and understand the hardware like I do CRT. I know they're just "consumer quality" and nothing like a Barco or DPI inside (which is why they aren't $20,000+), but I'd love to see how they compare in build quality to your average run-of-the-mill ~$1000-1500 Epson or Panny. They sure seem to be much more solidly built going by weight and overall feel.
fefrank
| Posted: Sat Nov 03, 2012 12:06 am Post subject: |
| ecrabb wrote: | Thanks, guys! Cool stuff.
SC |
These run of the mill projectors you are talking about are engineered to fail sometime sooner than later. Yeah there is people out there who have had better luck with cheap lcd or dlp machines. I've heard of stories of people who've had a cheap Lcd projector for years and years with no problems. My dad for example bought the first projector i've ever used in 2002, it was an epson moviemate 25 3LCD. That projector has never had any problems since he bought it other than normal maintenance like bulbs every 2500 hours and filter cleaning, and he still uses it everyday to watch movies. But when you talk about JVC is a whole different story. These things are made with high quality stuff. Let me tell you, we make stuff for both companies. And polarizers made for these 2 companies are very different in performance and, price!. In my opinion you wont be getting a slacker if you buy a JVC for 4,000 dollars and use it for the next 5-7 years. On the other hand if you get and epson for 1500, I could assure you'll end up having to pay 4,000+ in the next 4 years buying other projectors once the 2 year warranty is over. The internals in a JVC compared to an epson 8700UB is like comparing a Hyundai enlantra with a Chevy Camaro. Yeah you get a real nice warranty for the hyundai and they are "reliable cars" until your warraty is over. But with a chevy camaro you get the performance, the name,and a very nice warranty. I all comes down to the awesome phrase " You get what you pay for"
fefrank
| Posted: Sat Nov 03, 2012 12:10 am Post subject: |
| digitalayon wrote: | | Quote: | | It really depends on the projector and the applications. Glass is mostly used for high temperature applications. I am positive that your JVC projector has a glass polarizer in it just because is used for contrast and visual light. If it's not completely glass It would still be glass but mixed with other components. Organic polarizers (plastic. thick paper mesh ect.) are too delicate for a machine that gets that hot. You could get lots of issues with organic polarizers, that's why the industry now is going inorganic. You get more efficiency, a better picture and much better durabilty, and even in extreme temperatures you get much better performance. |
Well....I guess I should get to know our products better!!!! I got to know JFETS last week. |
JFETS are pretty cool. But I don't know anything about them. Aren't those like xray technologies?
digitalayon
| Posted: Sun Nov 04, 2012 4:39 pm Post subject: |
Yeah they are xray division.
