| Posted: Wed Oct 24, 2012 3:00 am Post subject: Hey Scott! Remember the Medium Retrace mod? |
Guys
This would give more useful width in what is now short retrace on a Marquee. If my computer hadn't blown up two years ago I'd post it myself......
| Posted: Wed Oct 24, 2012 7:34 pm Post subject: |
this is something that's done to the HDM?
| Posted: Wed Oct 24, 2012 7:43 pm Post subject: |
Yes
Providing Scott gets back to us
I had the info in an e.mail and it was lost in a crash.
| Posted: Thu Oct 25, 2012 7:37 pm Post subject: |
Guys
I was hoping Scott would visit us here, he has the info for this.
htguy1
| Posted: Fri Oct 26, 2012 4:31 am Post subject: |
Calling Scott! Come back and help us!
tse
| Posted: Fri Oct 26, 2012 1:26 pm Post subject: |
The retrace caps (C4, 5, 6, 7, 10, and 11) values can be increased to increase the flyback time. This will decrease the "write" time which makes the active video time cover more of the raster. Probably the best thing to do is just parallel the caps that are already there with 1nF 1000V polypropylene parts. If the raster "wraps" around the caps are too big if still too much unused raster add slightly higher value or more of the 1nF parts. Increasing the cap value decreases the flyback voltage so there is little danger in properly adding caps of reasonable value. I have included a Mathcad file that calculates the the voltages and cap values.
Good Luck,
Scott
| Description: |
| Filesize: |
45.37 KB |
| Viewed: |
7518 Time(s) |
Thomas Jefferson
| Posted: Fri Oct 26, 2012 2:04 pm Post subject: |
So Scott
This affects both short and long retrace?
tse
| Posted: Fri Oct 26, 2012 3:06 pm Post subject: |
Both long and short will increase but the long will increase less than short.
Scott
Thomas Jefferson
dvh99
| Posted: Fri Oct 26, 2012 4:22 pm Post subject: |
yes it is.
on long retrace i think an extra cap is switched on with a relay an put in parallel with the caps across the fets.
| Posted: Fri Oct 26, 2012 4:59 pm Post subject: |
Guys
I have some caps ordered for testing, let me get back to you in a week or so........
tse
| Posted: Fri Oct 26, 2012 5:15 pm Post subject: |
| Nashou66 wrote: | Thats looks like the formula in the Marquee thread regarding those Cree fets. Is it the same?
Athanasios |
Yep.
Scott
Thomas Jefferson
thewolfman
| Posted: Fri Oct 26, 2012 9:43 pm Post subject: |
deleted
dturco
| Posted: Fri Oct 26, 2012 9:59 pm Post subject: |
| tse wrote: | The retrace caps (C4, 5, 6, 7, 10, and 11) values can be increased to increase the flyback time. This will decrease the "write" time which makes the active video time cover more of the raster. Probably the best thing to do is just parallel the caps that are already there with 1nF 1000V polypropylene parts. If the raster "wraps" around the caps are too big if still too much unused raster add slightly higher value or more of the 1nF parts. Increasing the cap value decreases the flyback voltage so there is little danger in properly adding caps of reasonable value. I have included a Mathcad file that calculates the the voltages and cap values.
Good Luck,
Scott |
Scott, in about two years I'll be able to do this. But right now, it makes no sense at all. How can a voltage or re-trace length be 10 to sixth power negative? Or is that just to show how small it is in length in relation to the fictional start point of 1 meter?
You don't have to answer, I just wondering out loud, as I have yet to tackle my math requirements starting at Algebra...
101
http://www.hulu.com/firefly
| Posted: Fri Oct 26, 2012 10:34 pm Post subject: |
| dturco wrote: | | tse wrote: | The retrace caps (C4, 5, 6, 7, 10, and 11) values can be increased to increase the flyback time. This will decrease the "write" time which makes the active video time cover more of the raster. Probably the best thing to do is just parallel the caps that are already there with 1nF 1000V polypropylene parts. If the raster "wraps" around the caps are too big if still too much unused raster add slightly higher value or more of the 1nF parts. Increasing the cap value decreases the flyback voltage so there is little danger in properly adding caps of reasonable value. I have included a Mathcad file that calculates the the voltages and cap values.
Good Luck,
Scott |
101  |
When the power is negative it goes fractional. 10 to the 6th power negative would be 1/1000000 or 0.000001
dturco
| Posted: Fri Oct 26, 2012 11:23 pm Post subject: |
| Quote: | | When the power is negative it goes fractional. 10 to the 6th power negative would be 1/1000000 or 0.000001 |
I get its a fraction of something, just like when I'm doing microscope work the object is really small. But the size is always related to the starting point of 1 meter.
Down 10 to the 6 negative as 6um, as a measurement or 1 millionth of a meter. I get that because I can see it in the scope but as pure math... I freeze.
| Posted: Fri Oct 26, 2012 11:31 pm Post subject: |
It's fractional to where it is being applied. If it's time it is fraction of a second. If it's voltage it's fraction of a volt. If it's cap value it's fraction of a farad. If it's resistance it is a fraction of an ohm...... shall I continue?
dturco
| Posted: Fri Oct 26, 2012 11:35 pm Post subject: |
| macgyver655 wrote: | | It's fractional to where it is being applied. If it's time it is fraction of a second. If it's voltage it's fraction of a volt. If it's cap value it's fraction of a farad. If it's resistance it is a fraction of an ohm...... shall I continue? |
Ahhh, the starting point is known; because of the application. Got it.
