getting 72hz to my 9500LC....
htguy1
Posted: Fri Oct 19, 2012 2:56 pm    Post subject: getting 72hz to my 9500LC....
I was looking at the used video gear adds and was wondering if the Lumagen vision hpd would be able to feed my 9500lc 72hz? (I can't recall if it could or not)
Next question, would that be an upgrade over sending 1080p60hz from a mome hdmi 1.2 stand alone box with bnc output? (I don't want to spend the money only to find out that its a step backwards!)
God bless...
Mark
Posted: Fri Oct 19, 2012 8:32 pm    Post subject:
Not with 1080p but it will at 800p for 2.4 aspect via the DVI out(digital)
However if you get a moome MUX HD and use it before the Lumagen then you can output 1080p@72 via the analog RGBHV outs
Also the DVI can be set to do RGBHV as well.
Posted: Fri Oct 19, 2012 8:36 pm    Post subject:
The MUX is a great piece of gear. it has two outputs and now has HDMI audio. so for what you have is the ability to hook up 4 HDMI sources to the MUX-HD then send one out to an AV receiver for the audio with no HDCP issues and the other to the Lumagen. Now in the Lumagen you can set up that Single input to to have 4 memories for each HDMI source that went into the MUX HD!! And calibrate each source with its own greyscale?Gamma settings!!!
