Creating channels: 2,35.1 - 1,85.1 and 1,78.1 on a marquee
thewolfman
Posted: Thu Oct 18, 2012 5:39 pm    Post subject: Creating channels: 2,35.1 - 1,85.1 and 1,78.1 on a marquee
Hello again..
I’m having problems understanding the manual for creating channels for 1,85.1 and 1,78.1. I gotten some help on the matter, but got stuck on why the 2 new channels keep flipping back to the first primary channel.
I always use 1080p@60Hz from my computer and like to create 2 more channels just like it, only its been shrunken to fit within my 2,35.1 screen. A CIH so to speak.
I have check marked the 3 channels, within channel listing, and named them, and can flip through them via source up and down, but they always go back to first one if I leave it alone. How can I get it to stay in channel 2 and 3 so I can perform a geometry and convergence on those? Source button shows Input 02 is locked with a key - but channel 01 has got no such lock key next to it. Shouldn’t it the other way around?
Should channel 1 always be in locked mode when performing geometry on channel 2 and 3?
Posted: Thu Oct 18, 2012 5:42 pm    Post subject:
Hello
Turn off ASR if in use, it would jam your channel selection.
thewolfman
Posted: Thu Oct 18, 2012 5:47 pm    Post subject:
Hi, ASR has been turned off the whole time.
Posted: Thu Oct 18, 2012 6:42 pm    Post subject:
Hello
Read out your Channel list completely; CH Number, Name, Input, Recall, we will see what the problem is.
thewolfman
Posted: Thu Oct 18, 2012 6:50 pm    Post subject:
Hi there... Ok, here it goes.
CH01 Name: 1080p Input:02 Recall (Nothing) U/D v
CH02 Name: 1,85.1 Input:02 Recall (Nothing) U/D v
CH03 Name: 1,78.1 Input:02 Recall (Nothing) U/D v
Posted: Thu Oct 18, 2012 6:58 pm    Post subject:
Hello
You are only using one memory! For CH01 use RECALL 01, for CH02 use Recall 02 and so on.
thewolfman
Posted: Thu Oct 18, 2012 7:05 pm    Post subject:
It’s working now, not sure I'm all the way home yet, but they stay where they are at least. Thank you! I'll keep going at it.. Smile
Posted: Thu Oct 18, 2012 7:14 pm    Post subject:
Make sure after you dot he set up for each channel you then go in and unlock, then re lock the memory for that channel before shutting it down. I do this every time I re do the convergence just to make sure it is saved.
thewolfman
Posted: Thu Oct 18, 2012 7:24 pm    Post subject:
The picture got pretty messed up at first, but going to Picture and changing Retrace back to short made all channels looking right again. So now I can get going finally.. Thanks again, both of you.
Phoenixed
Posted: Thu Oct 18, 2012 9:16 pm    Post subject:
I would also use the marquee loader program as well for a backup. That way in case something really bad happens you have a "hard copy"
Planar PD-8150/Runco LS-5
thewolfman
Posted: Thu Oct 18, 2012 9:43 pm    Post subject:
Where’s the delete button when you need it. I Thought for a secound it could do more than that.
Posted: Thu Oct 18, 2012 9:50 pm    Post subject:
thewolfman wrote:
So that’s how one upgrades the different firmwares? I have software 4.1. Can that be up graded somehow? Should be fun getting to learn that also. I just downloaded it..
No the Software is for controlling the Marquee and saving AND UPLOADING DIFFERENT SETTINGS.
The firm wear can only be upgraded with new chips unless you have an eprom reader and some one else's newer chip to copy.
