dentree
Joined: 01 May 2009 Posts: 247 Location: Melbourne Australia
TV/Projector: BARCO GRAPHICS 808 BARCO GRAPHICS 801
| Posted: Thu Sep 20, 2012 3:13 pm Post subject: Connectors |
I have a BARCO 808 with a 9 pin D shell port 3 input, the manual says this is a RGB input, I have a set top box with a 15 pin D shell as an output, with the appropriate gender changer will this work to give me TV pictures from the set top box?
Many thanks
Trevor
| Description: |
| Would this be what I would need, assuming this arrangement would work |
| Filesize: |
34.86 KB |
| Viewed: |
3855 Time(s) |
| Posted: Thu Sep 20, 2012 3:19 pm Post subject: |
Hello
What is the signal format from the box? Which signal is on which pin for the box and the projector? You cannot randomly order a prefab cable and expect it to fit your situation.
Decibel
Joined: 31 May 2007 Posts: 904 Location: Roma - Italia
dentree
| Posted: Fri Sep 21, 2012 2:37 am Post subject: Connectors |
Hi Tim in phoenix,
Many thanks for your reply, The set top box has variable output resolutions in both progressive and interlaced flavours all the way up to 1080p, I assume the output 15 pin is analogue as it will plug straight into a telly ( not very knowlegble about these things ) this is the info from Curts pages don't know whether this info relates to a pin layout on a stock standard 15 to 9 pin device.
Perhaps I am not understanding any of this correctly, but the pin numbers on the 15 pin side seem to relate to the 9 pin BARCO input.
Many thanks for your time
Trevor
| Description: |
HD15 (VGA) Signal Barco Port 3 (D9) 1 Red 3 2 Green 4 3 Blue 5 4 (No Connection) - 5 (No Connection) - 6 Red Ground 2 7 Green Ground 6 8 Blue Ground 7 9 (No Connection) - 10 (No Connection) 1 11 (No Connection) - 12 (No Connection |
| Filesize: |
25.52 KB |
| Viewed: |
3778 Time(s) |
| Posted: Fri Sep 21, 2012 2:46 am Post subject: |
Why not use a standard fury Barco breakout cable for port 3 ?
dentree
| Posted: Fri Sep 21, 2012 5:30 am Post subject: Connectors |
I am afraid I do not know what "standard fury Barco breakout cable" is, sorry to be so vague about this
Phoenixed
| Posted: Fri Sep 21, 2012 6:07 am Post subject: |
Ignore this post.
| Posted: Fri Sep 21, 2012 7:35 am Post subject: |
| Phoenixed wrote: | Here
That would be an RGBHV breakout cable for input 5 not not input 3.
barclay66
Phoenixed
| Posted: Fri Sep 21, 2012 3:46 pm Post subject: |
My bad.
