digitalayon
| Posted: Mon Sep 17, 2012 8:08 pm Post subject: ok.....what card am I looking at that is bad? |
I have opened up a BD808S and the cards look like they have been gone through by a tech and checked off as good but there is one that is labeled as bad. It has a good size heat sink and large capacitor on it and sticker is 1065907. In looking at it, it looks as though a diode went out and a new one was mounted but it was relocated on the back of the card. Guessing the good and bad tape was left on on it. So I think it was repaired. It might be the horizontal deflection board. Am I right?
barclay66
| Posted: Mon Sep 17, 2012 9:06 pm Post subject: |
The number You indicated is the board's serial number and not the part number. Look for another sticker next to the board's connectors. Should start with R7....... With this number it's easy to find out what board You have...
Regards,
barclay66
| Posted: Mon Sep 17, 2012 9:17 pm Post subject: |
Sheesh, I should just shut down the main site...
http://curtpalme.com/Barco1208_Layout1.shtm
If it's a resistor on the H shift board, then that's a BArco revision and is stock.
digitalayon
| Posted: Mon Sep 17, 2012 9:50 pm Post subject: |
HA HA.....thx Curt yeah it the Horz Output board. If the pictures in the reference were yours Curt, you might have worked on this. Same handwriting on masking tape. Unless that is a industry standard.
| Posted: Mon Sep 17, 2012 10:34 pm Post subject: |
Yep, my writing, my pix. I do send boards out often with 'good' written on them, so somewhere in the past, I've had my fingers in that set somehow. Walk away from it. It's gotta be junk.
| Posted: Tue Sep 18, 2012 2:59 am Post subject: |
| Curt Palme wrote: | Yep, my writing, my pix. I do send boards out often with 'good' written on them, so somewhere in the past, I've had my fingers in that set somehow. Walk away from it. It's gotta be junk.  |
Now THAT is what I call good advice
digitalayon
| Posted: Tue Sep 18, 2012 1:00 pm Post subject: |
Man Curt takes a lot of sh*t from us!
| Posted: Tue Sep 18, 2012 1:20 pm Post subject: |
Hey I started it!
