Marquee focus module, 100uF bi-polar caps?
mutantaction
Posted: Wed Sep 12, 2012 12:03 pm    Post subject: Marquee focus module, 100uF bi-polar caps?
Hi!
Quick question:)
On the Marquee focus module there's a 100uF 25V+ cap on each RGB line...this is bi-polar. However,
the printing on the PCB shows a + sign...can these be swapped for standard polarized caps?
Thanks!!
Posted: Wed Sep 12, 2012 12:21 pm    Post subject: Re: Marquee focus module, 100uF bi-polar caps?
mutantaction wrote:
Hi!
Quick question:)
Thanks!!
I never noticed that on the PCB, i would definitely stay with BP caps.
barclay66
Posted: Wed Sep 12, 2012 2:28 pm    Post subject: Re: Marquee focus module, 100uF bi-polar caps?
These caps are connected to the Dynamic Focus Amplifier output and its output signal can swing between +24V to -24V. Therefore bipolars are mandatory. Using polarized caps would only be possible if those had a much higher voltage rating which would include a higher tolerance versus wrong polarity...
Regards,
barclay66
mutantaction
Posted: Wed Sep 12, 2012 3:48 pm    Post subject:
Ok, thanks guys! Just ordered some Rubycon 100uF 63V bi-polar!
Thanks for the advice;)
