Andi42
| Posted: Thu Sep 06, 2012 9:25 am Post subject: Moome IFB FULL-HD V1.3 Temperature Problem |
I have a Moome IFB FULL-HD V1.3 (that one without 3D but with the modded capacitors) in my Sony G70.
Depending on room temperature about 45-60minutes after the projector started up, the picture starts to flicker and the luminance rises (black to a dark grey and everything else respectively). The flickering lasts for about 1 minute and then the 'process' is done.
No I've found out that it's the Moome card that causes the problems. Having removed the panel I could blow air into the card-slot.
In the moment when the flickering starts I blew into the card-slot and the problem went away (reproducible).
Does anyone (Moome himself?) know about the issue and possibly a solution for it? Is is a bad capacitor (some are getting very warm) that causes the trouble?
If I get no answer I'll have to check by partially cooling certain components with a cooler spray. But that's difficult inside the slot...
Cheers
Andreas from Munich (Germany)
