Vision 1, no high voltage
trebortaergeht
Posted: Wed Sep 05, 2012 6:14 am    Post subject: Vision 1, no high voltage
I went to turn on my projector yesterday, but high voltage never came on. There are no error lights lit, and i have re-seated every chip, board, and connector to no avail. What is the next step for troubleshooting this, i don't have any spare boards to swap with.
Revox
Posted: Wed Sep 05, 2012 10:19 am    Post subject:
I noticed that the failure detection of the HV on a Barco 909 does not always work as it should.
My tip is a bad quadrupler or a bad EHT board (as "usual" i would say).
You can check the EHT board. If you probe the Quadruplers input, be carefull! All Outputs can be on life potential, so you must probe differential.
Greetings from Germany, Stefan
Posted: Wed Sep 05, 2012 1:09 pm    Post subject:
Is it safe to assume that it's a 909?
Posted: Wed Sep 05, 2012 1:30 pm    Post subject:
Its a Marquee clone.
Posted: Wed Sep 05, 2012 2:01 pm    Post subject:
Sorry, didn't read the title. Smile
You most likely have a bad HVPS, but a bad H board can also cause this. Try reseating the HDM, and if that doesn't work, most likely it's the HVPS. I have stock of both.
Revox
Posted: Wed Sep 05, 2012 4:22 pm    Post subject:
Sorry, i thought that the vision one is a barco based set.
In My Marquee when the HDM failed temporary, there was a short "sprtzsprtz" noise of the HVps, but i don't know what is happend when the HDM totally fails.
Posted: Wed Sep 05, 2012 6:35 pm    Post subject:
pull out the horizontal deflection board (vertical board in gold box between Blue and green tube) , clean the contacts on the bottom with isoproply alcohol and an old soft tooth brush. Pull off the small daughter board (held on with plastics screw), clean those pins too. The daughter-board pins will typically get so oxidized that the board is hard to remove but Work it evenly until it pops off
Re-assemble and test.
If machine still doesn't run then the HV power supply is likely bad
