Noiseless HV arc, Marquee 9" Blue fixable?
Posted: Mon Aug 27, 2012 11:12 pm    Post subject: Noiseless HV arc, Marquee 9" Blue fixable?
Guys
Just installed three NOS Panasonic tubes in a 9500 Ultra; the high voltage crashes and comes back into focus every 3-4 seconds. Unplugging anodes one at a time isolated the problem to the blue tube. Could this be fixable by tapping on the gun? Problem was worse with higher contrast. I have only seen this twice in twelve years.
Posted: Tue Aug 28, 2012 12:16 am    Post subject:
Did you try a different neck board?
Posted: Tue Aug 28, 2012 1:39 am    Post subject:
No, but a different tube works with the original neckboard.
digitalayon
Posted: Tue Aug 28, 2012 7:32 am    Post subject:
What tubes are these?
Posted: Tue Aug 28, 2012 7:36 am    Post subject:
What about a different HT spot on the splitter. Switch splitter socket.
dvh99
Posted: Tue Aug 28, 2012 12:21 pm    Post subject:
did you squeeze the aquadag connectors before reinstallment?
Posted: Tue Aug 28, 2012 12:51 pm    Post subject:
Guys
These are LCP09s. All connections are tight. This projector is crated to ship out this morning so it will be a few days before I have another chassis on the bench to test with. I want to take the focus and flare yokes off for a better look.
Posted: Tue Aug 28, 2012 1:27 pm    Post subject:
My guess is an intermittent H-K short or some similar contamination within the tube neck. Super rare, but possible. I would try a different neck board for S and G first though.
Posted: Sat Sep 01, 2012 7:38 pm    Post subject:
This is really weird.....
I pulled out this tube again, I wanted a better look at the arcing problem, so I pull off the flare and focus yokes so I can look into the gun. I fire it up and........it doesn't arc now!. I am wondering if the yokes were damaged somehow and induced the arcing.
