Barco data 600 inputs
dvb1994
Posted: Mon Aug 27, 2012 6:46 am    Post subject: Barco data 600 inputs
I just got a very old Barco data 600, and i was wondering if i can connect it to my macbook using vga-bnc cable( like this one http://elektronik-lavpris.dk/imageviewer.php?products_id=96052&image_id=75218&viewer_imagesize_big=900 ) ??
Thanks in advance!
//Daniel Balsby
Posted: Mon Aug 27, 2012 9:20 am    Post subject:
The short answer: Yes Smile
It should handle 720p and 1080i signals
dvb1994
Posted: Mon Aug 27, 2012 9:53 am    Post subject:
Is there a long answer? Razz
Can the macbook output RGBs?
Posted: Mon Aug 27, 2012 10:00 am    Post subject:
It should accept the signal, but these sets are very old now, they die more often if they driven hard, but at least the spare parts are costs next to nothing Smile
If your macbook has a similar port you can connect to the pj.
dvb1994
Posted: Mon Aug 27, 2012 10:04 am    Post subject:
It does have a VGA output, but dont i need to somehow convert the signal from RGBHV to RGBs?
Posted: Mon Aug 27, 2012 10:10 am    Post subject:
They are the same, all signals are present in the VGA port in addition it has some more communication pins, but you don't need that for a projector. Every analog monitor gets it's picture through Red, Green, Blue, Horizontal sync, Vertical sync signals.
dvb1994
Posted: Mon Aug 27, 2012 10:16 am    Post subject:
But dosent the BD600 need composite sync?
esquilo
Posted: Mon Aug 27, 2012 10:42 am    Post subject:
hello
you can try this http://www.cinetson.org/phpBB3/tritubes-f7/synchro-rgb-vers-synchro-code-rgbs-t36044.html
Salutations
Posted: Mon Aug 27, 2012 1:11 pm    Post subject:
Easy. Combine the H and V sync signals via BNC 'T' connector, and plug into the S input:
http://www.ebay.com/itm/1PCS-BNC-Male-To-2-BNC-Female-Coaxial-Coax-RG59-T-Connector-Splitter-Adapter-/140793857185?pt=US_Surveillance_Cables_Adapters_Connectors&hash=item20c7f7c4a1#ht_1802wt_1186
esquilo
Posted: Mon Aug 27, 2012 3:03 pm    Post subject:
I know this technique because I used it, but the sync voltage is coded incorrectly and unstable. More you risk, a term abyss of your entry card ... you have to choose.
cordially
PS sorry for my English, I use a translator Mr. Green
esquilo
Posted: Mon Aug 27, 2012 3:08 pm    Post subject:
abyss >> damaging ... sorry
Posted: Mon Aug 27, 2012 3:13 pm    Post subject:
No, there is no risk of damage. Both sync signals need to be negative. The set will not sync if you have positive sync which is what most computers now put out. You would need an Extron sync inverter box between the computer and the projector:
http://www.ebay.com/itm/Extron-RGB-202-Rxi-w-ADSP-Two-Input-Universal-Analog-Interface-/140834272241?pt=LH_DefaultDomain_0&hash=item20ca6073f1#ht_2898wt_1186
dvb1994
Posted: Mon Aug 27, 2012 7:21 pm    Post subject:
Thanks a lot Curt! =) I really appreciate all the help...
Is there any way to do it cheaper considering the projector cost $10 and the box is $75 with shipping?
Posted: Mon Aug 27, 2012 9:05 pm    Post subject:
Yes, if you can find a video driver for the computer that forces negative sync. THe computer guys will be more helpful than I am in that department.
dvb1994
Posted: Tue Aug 28, 2012 8:55 am    Post subject:
Thanks again!
I made a new topic in another part of the forum, so i hope i get lucky there Smile
