Sony 1252
416ray4538
Posted: Sun Aug 19, 2012 11:44 pm    Post subject: Sony 1252
I've been fighting a battle Of wills with an Ampro for about 10 months now. A customer gave me a Sony 1252 partly out of pity and partly out of finding a home for his PJ. He lit it up before I loaded it in the truck and it it worked. I'm lost. I connected RBG from from my DVD and that's as far as I got. The pj makes noise. The guns glow. What am I missing
When the first clock was invented, how did they know what time to set it to?
No point being pessimistic; it probably would't work anyway.
Posted: Sun Aug 19, 2012 11:48 pm    Post subject: Re: Sony 1252
Do you mean the component output or does your DVD player have a VGA out?
The 1252's are dead simple. Try S-video and see if you get a picture.
tanwn
Posted: Mon Aug 20, 2012 12:32 am    Post subject:
you can't use component on a 1252 if i am not wrong, you need to use VGA 5BNC out or buy a hdfury / moome.
Posted: Mon Aug 20, 2012 1:23 am    Post subject:
http://www.curtpalme.com/CRTPrimer_17.shtm
416ray4538
Posted: Mon Aug 20, 2012 1:25 am    Post subject:
Using 3 wire rbg
Got a picture now
Posted: Mon Aug 20, 2012 1:59 am    Post subject:
416ray4538 wrote:
Using 3 wire rbg
Got a picture now
Is the picture green?
Posted: Mon Aug 20, 2012 7:22 am    Post subject:
With an IFB-12 card it is possible to connect component signal to a 1252
Posted: Mon Aug 20, 2012 7:36 am    Post subject:
Yep
416ray4538
Posted: Wed Aug 22, 2012 11:33 pm    Post subject:
416ray4538 wrote:
Using 3 wire rbg
Got a picture now
Yah green.
I have a few boxes for translating signals; maybe one of those?
I'm trying to take Curts advice for centering the picture on the screen. If I read correctly I want to fill (almost) the raster ,then centre what's projected onto my screen.
So: The PJ is hanging partway up to the ceiling and I've got the picture centred on the screen (left/right) and the picture mostly fills the raster when looking into the guns; the green is the only one very bright.
This is an RGB vs component issue isn't it?
Posted: Thu Aug 23, 2012 12:12 am    Post subject:
Yes, you need a trascoder to go YPbPr to RGBHV or if your player has HDMI an HDFury or Moome card
416ray4538
Posted: Thu Aug 23, 2012 12:28 am    Post subject:
Stock 1252
I'll try the 2220
Posted: Thu Aug 23, 2012 12:31 am    Post subject:
2200 is great! Make sure you have your player set to 480p and 16:9 enhanced, widescreen etc...
416ray4538
Posted: Sun Sep 02, 2012 7:01 pm    Post subject:
2 little problems.
1) My screen is 5' by 9' so 123 " I run out of sideways adjustment for red and blue. That means I have to change spacers? And if so "anyone have some spacers?
2) With the pj hanging about 3 " from the ceiling and level the picture is about 3' low. Tilting the pj to move the picture is no problem but what about it being level? Is that not as important as the instructions say?
Posted: Sun Sep 02, 2012 11:35 pm    Post subject:
Try the spring spacer mod:
http://www.curtpalme.com/Sony125x_SpacerMod1.shtm
