Test Patterns
This forum is locked: you cannot post, reply to, or edit topics.   This topic is locked: you cannot edit posts or make replies.    CurtPalme.com Forum Index -> ChromaPure Products
giogt600
Posted: Mon Jul 16, 2012 11:50 pm    Post subject: Test Patterns
Hi all
What is the general rule of thumb when displaying test patterns while calibrating different displays ? Which displays should you use window patterns and which full field patterns . Also does this apply to projectors as well i.e.
LCD vs DLP ?
g
TomHuffman
Posted: Mon Jul 16, 2012 11:56 pm    Post subject:
You must use window test patterns for plasma and CRT. For all other display types you may use either.
ChromaPure calibration software & meter packages at CurtPalme.com discounted prices!
giogt600
Posted: Tue Jul 17, 2012 12:00 am    Post subject:
Many thanks Tom....
gio
Abia045
Posted: Tue Feb 04, 2014 12:38 pm    Post subject:
Am I correct that when I do only front digital projector calibrations I have to select ''Fixed Target From Gamut'' for projectors that has CMS and all other projectors select ''Calculated Target''?
go now
solarmovie
TomHuffman
Posted: Tue Feb 04, 2014 6:37 pm    Post subject:
No, these issues are unrelated. Except under unusual circumstances, always use ''Fixed Target From Gamut''.
This forum is locked: you cannot post, reply to, or edit topics.   This topic is locked: you cannot edit posts or make replies.    CurtPalme.com Forum Index -> ChromaPure Products All times are GMT
