Home Theatre CRT projectors
Charlie30960
Posted: Wed Jul 04, 2012 3:03 am    Post subject: Home Theatre CRT projectors
I have a DTV-947 and am trying to set it up. Although the manual discusses memories it doesn't say how to access them or to apply them once created to a source! Any tips on that? Also, I have a remote for the VFD-4402 processor, but it refuses to work, even though there are new batteries in it. Is there an address issue or something like that that - again the manual isn't specific enough!
Dave..
HK-Steve
Posted: Wed Jul 04, 2012 6:40 am    Post subject:
Best way to check if the remote is working, is get a camera, or phone with camera,
point the remote at the camera and press a button on the remote, the camera should show the IR LED flashing white. if not, then the remote is busted.
Sorry, can not help with the 947.
Cheers
Posted: Wed Jul 04, 2012 2:23 pm    Post subject:
The memories are automatically selected depending on the input and resolution. The most important thing when converging/setting up the projector is to use the ;genlocked' source mode. you also need a live video input signal running to the projector at all times. Failure to do so will let the projector jump to a random memory location, and your setup work may be lost if you don't have a picture running to the set while setting it up.
