Ampro I2C error
donr
Posted: Fri May 11, 2012 8:07 pm    Post subject: Ampro I2C error
Hi guys
My Ampro 4000G pj refuses to start. I get an error 20 at 74 and then error 20 at 4e messages on the remote. Could this be an I2C error?. The battery tests 3.36V. It was working fine the previous day. I removed the cpu board to find out the battery # which is a Keeper ll LTC-7P. Could it be that since voltage is lower than 3.5V cause this error and where in Canada can I find this battery? Thank's
Don
incova
Posted: Fri May 11, 2012 9:41 pm    Post subject: HI
Double check if it really is the battery, if it is get it done by Curt not worth doing yourself he has the batteries and the knowledge to install them, well worth the price. From what Scott told me the battery can go down a bit and everything should be ok but I am not sure what the limit is.
The more I learn
the less I know.
Posted: Fri May 11, 2012 10:07 pm    Post subject:
Over 3 volts it should be OK. You have a communication prob,em between the CPU board and the registration board. It shouldn't be the battery, but it might be an idea to change it. I have two 2000 chassis left that I can partially test boards on, but have thrown out most of the 2000/4000 stuff. If you want, send them in, figure about $150 incl return shipping to fix.
donr
Posted: Sat May 12, 2012 10:53 am    Post subject:
Thanks guys but, I am wondering if it is worth fixing. Although it does throw a nice picture on my 8ft screen, it is a 1991 vintage. I have a mint 6PG xtra and the idea of hanging this one up has been running in the back of my mind for a while. I just never got around to it because the Ampro was trouble free and I did not want to lose any image quality considering that the Nec are 7" tubes. What do you think? Will there be much of a difference?
Don
Posted: Wed Feb 05, 2014 6:31 am    Post subject:
I just inherited this projector. ( THANKS DON! )
I'll have a look at this on the weekend time permitting.
digitalayon
Posted: Wed Feb 05, 2014 8:12 pm    Post subject:
UM....that NEC will spank the AMPRO!!!!
Posted: Wed Feb 05, 2014 8:13 pm    Post subject:
Just curious, have you done a side my side comparison?
Posted: Wed Feb 05, 2014 9:01 pm    Post subject:
With an unfunctional AmPro? It's needless! Mr. Green
Posted: Thu Feb 06, 2014 1:00 pm    Post subject:
You never know. The NEC could have the "scrambled mess" issue ;D
