HaydnG90
| Posted: Mon Apr 23, 2012 7:45 pm Post subject: VP with 1080P@72Hz output capability |
Rather than contaminate the other thread I thought I'd start a new one.
I've always wanted to be able to feed the G90 with a 1080P @ 72Hz signal. I always thought the only option was either HTPC (not an option) or the high priced Lumagen XS+/XE+. Reading in another thread it appears the DVDO VP50 Pro is capable of this output for a lot less money. From the spec sheet......
"Progressive Cadence DetectionTM– Enables 24/48/72Hz and 25/50/75Hz output from film-based content at 480p, 576p, 720p and 1080p resolutions"
Are both units really capable of processing the bandwidths needed at this resolution? If you're on a budget is there a reason not to choose the DVDO?
Phoenixed
| Posted: Mon Apr 23, 2012 8:58 pm Post subject: |
I have a vp50 but no g90 to test it. I don't think my 8500 would even sync. However I do have a 9500 I could test for ya if helps.
stridsvognen Guest
| Posted: Mon Apr 23, 2012 9:01 pm Post subject: |
https://www.curtpalme.com/forum_archived/viewtopic.php@t=11205.html
I'm using the VP50, and think its a much better unit than the VP50 Pro. You will save money buying the old VP50, and get better PQ and less firmware bugs. I need to do a lot of underscan to center the picture right after using the data allowing 72hz, but i love 72hz, its so smoooooth.. Its also possible to run 75 hz with max 1800x1010 75hz
The VP50 is good for making the color space conversion from 4:2:2 to RGB and deinterlacing, but its don't do perfect upscaling. To much ringing. I use my Denon DVD A1XVA / 5900 for outputting 1080i that is almost perfect to me.
There is no help to get from DVDO. tryed write DVDO support 3 times, no reply.
Im sure the new Lumagen is better all around, but also much more expensive.
| Posted: Mon Apr 23, 2012 10:37 pm Post subject: |
You might try to contact Black Magic and see if they can add 72 support to the Teranex or if it is software upgradeable.
