| Posted: Tue Apr 24, 2012 3:32 pm Post subject: |
It might work, but how is questionable. As you can see it is unable to produce even 1080p, probably because of the speed of USB or they are using low-end (low-speed) RAMDAC which would end up on weak graphics quality. Also this is a soft-adapter, it uses purely the resources of the main cpu. For office use it might be ok, but for HT it is useless IMHO.
