Any way to remove wrinkles from screen ?
jeffslife
Posted: Wed Apr 11, 2012 3:55 am    Post subject: Any way to remove wrinkles from screen ?
DA LITE 103" on an aluminum frame
I put it all together now what ? Wait ? heat ?
We are ALL job creators !
Posted: Wed Apr 11, 2012 4:23 am    Post subject:
Give it a week on the frame before you do anything.
If it still has wrinkles after a week or so, you can try a hair dryer on low heat to warm the areas with the creases. DO NOT use a heat gun or even overheat it with the hair dryer because the damage will be permanent. You just want to warm it up a bit to relieve the tension. Keep the hair dryer moving and use large and small circles to evenly warm the screen, move to another area to let an area cool, then come back to it again.
Some guys have even used an iron wrapped in a towel, but I don't like to even touch the screen if possible.
jeffslife
Posted: Wed Apr 11, 2012 3:30 pm    Post subject:
Thanks Steve
