G70 Green Tube Not Able To Focus
haireez
Posted: Thu Apr 05, 2012 2:43 pm    Post subject: G70 Green Tube Not Able To Focus
Need help for my friend G70 set. I just came back from his place to take a look at his G70 green tube focussing issue. I tried to mechanically focus by adjusting on the green len but that doesn't help. Therefore, I tried MG focus hoping that I could focus the green tube.
Unfortunately, mechanical & electronic still could not focus the green tube. I do check on the tube face and the convergence line is also blurr. It only happen to green tube and no problem on blue & red tube.
Could this issue be focus board or the focus yoke issue could it be something else? Any advise would be greatly appreciated
2 White Vision 1
Posted: Thu Apr 05, 2012 2:53 pm    Post subject:
When you adjust the MG focus, does it do anything on the face of the green tube? If there's no change in the focus, I'd suspect the focus/V board.
haireez
Posted: Thu Apr 05, 2012 3:38 pm    Post subject:
Hi Curt,
There is a slight change when I adjusted the 2PH, 2PV & 4PA & 4PD but still not sharp enough and green convergence line is still fat.
Still not sure where the problem is.
2 White Vision 1
