Runco and Vidikron model numbers?
Boilermaker
Posted: Wed Mar 28, 2012 1:21 pm    Post subject: Runco and Vidikron model numbers?
I'm trying to use the Roomieremote app to control a couple systems that have an NEC XG'S projector and a VDC Marquee. Roomie's database shows several models of Vidikron and Runco and hopefully one of them will work. Does anyone know the model numbers of these projectors?
Bob
Posted: Wed Mar 28, 2012 2:06 pm    Post subject:
The Runco 991 and 991 Ultras are the NEC XGs. Remote codes are identical.
Boilermaker
Posted: Wed Mar 28, 2012 2:37 pm    Post subject:
Thanks -Just as I figured. The only models they list are the bulb models, so I'll have to learn how to "learn" the commands!
Thanks, Bob
Posted: Wed Mar 28, 2012 2:57 pm    Post subject:
Say Bob
The Vision One commands should run the Marquee. The PROJ ID may need setting to 000 or 001.
Boilermaker
Posted: Wed Mar 28, 2012 4:19 pm    Post subject:
Hi Tim,
Same thing as the NEC, Roomie only has the bulb stuff and I doubt that they use the same discrete on and off commands as the crt's did.
Bob
Posted: Wed Mar 28, 2012 9:09 pm    Post subject:
Okay
Wasn't there a website that had all sorts of CRT IR codes, Projector Central or something? Say Bob, perhaps if you edit your thread name to say IR or RS232 codes needed.
DB Cooper
Posted: Wed Mar 28, 2012 9:33 pm    Post subject:
I think remotecentral used to have them.
