Barco 800 Newb Question
jfrussell
Posted: Sun Mar 11, 2012 7:15 am    Post subject: Barco 800 Newb Question
Hey Everyone,
I'm kinda new to owning a projector like this. I got a Barco 800 several months ago off of Craigslist. A buddy of mine even took it to Curt to get it a clean bill of health. Everything was a go. But life took over and I am just now getting around to setting up the home theater. I am running into what I figure is a dumb question. A few points
- I got a Barco 800
- I have the HD Fury II
- I have it currently set up to an Xbox 360
- The Xbox is set to 1080i and RGB
The issue:
I have the xbox hooked up on input #4 and only the green tube is projecting.
Have tried:
- Using a different HDMI cable
- Adjusting the HD settings on the xbox
- On the HD Fury II, it is set to YUV
The signal doesn't seem to follow the green plug. So if I plug the green cable into the red/blue port, it does project red/blue.
Any help would be most appreciated.
Jason
jfrussell
Posted: Sun Mar 11, 2012 7:32 am    Post subject:
So partial update.
Was able to get the colors to come through.
However, on the HD Fury II, when I adjust the gamma almost at all, it starts to roll really bad. Any thoughts/suggestions?
Posted: Sun Mar 11, 2012 7:55 am    Post subject:
Is it outputting RGB or is it outputting component? Flick that switch back over on the HD Fury 2, YUV is component.
jfrussell
Posted: Tue Mar 13, 2012 7:04 pm    Post subject:
I will look tonight if I have time.
I am pretty sure it (you mean the Xbox?) is outputting RGB.
nunziom
Posted: Fri Mar 30, 2012 12:09 pm    Post subject:
I concur with jfrussell, had a similar issue when I first started playing with the HD Fury 2. Flick of the switch and it all came good.
Good luck with it.
