hansilili
Joined: 09 Mar 2007 Posts: 302 Location: Köln, Germany
| Posted: Mon Mar 05, 2012 1:38 pm Post subject: do the red and blue PGxtra tubes fit into an AC XG? |
This has probably been clarified a trillion times but I am to stupid to find it.
A mate has a XG75 with worn P16LJE08HKA tubes. Ho also has a set of decent PGxtra tubes P16LJE08HKA (green)P16LJE09BMB (blue) and P16LJE09RJA red. Can those simply be swapped. He also has plenty of xtra chassis for spares if needed.
THanks
hansilili
_________________ HansA, alles andere ist euer Bier!
A Rogers
| Posted: Mon Mar 05, 2012 2:23 pm Post subject: |
pretty sure that only the green from the xtra will fit the XG the blue and the red being too short.
Jeremy112
| Posted: Mon Mar 05, 2012 4:08 pm Post subject: |
AFAIK the XG only accepts the green NEC PG Xtra tubes from the 6PG/9PG Xtra. The Green tube is bigger than the red and blue (at least you would think it should be since the PG series is 7" and XG is 8" tubes)
| Posted: Tue Mar 06, 2012 6:11 am Post subject: |
Jeremy, a P16 tube is an 8 inch tube, not a 7 inch tube. Any PG XTRA set has got 8 inch tubes. A PG plain or PG Plus has got tube larger that 7 inch but under 8 inch, and these are genuine NEC tubes, or E8508 tubes as they are named.
This has come up numerous times before RE the fact that 09s will take the place of 08s, and i dont remember the outcome. HOWEVER i was told be a man who is well and truly in the know about these machines that the ONLY reason the 08s cant go into a PG XTRA is cause they are a touch longer, and you wont get the swing on them without modding the chassis abit. Big deal. They will work electrically, which as far as im concerned is all that matters.
I am not sure if the 09s can take the place of the 08s electrically. If you measure the lengths, you might find they are not much different and i doubt this will be much of an issue.
I will make a phone call and see if i can find out some info on the difference in length, cause im pretty sure Aussie Al on this forum has measured the difference in length ( prior to his purchase of XGs, we had plans of moving his tube mounts forward in his 9PG XTRA and using the brand new P16P16LJE08 set he has there... )
The HKA on the end is only the green tube
| Posted: Tue Mar 06, 2012 7:15 am Post subject: |
Just got off the phone with Aussie Al, he will open the lids on the XTRA and XG and measure the tube neck lengths at some point soon.
hansilili
| Posted: Tue Mar 06, 2012 10:35 am Post subject: |
Thanks for your support guys.
The xtra blue and red tubes are indeed shorter than the XG tubes, that is why the XG tubes wont fit into the xtra chassis. At least some say so an I never tried it. The question is, if the shorter xtra tubes can be put into a XG with worn tubes and if any electronics would need to be changed too.
Cheers
hansilili
A Rogers
| Posted: Tue Mar 06, 2012 11:43 am Post subject: |
| hansilili wrote: | Thanks for your support guys.
Cheers
hansilili |
The magnetics from the XG won't fit on the shorter blue and red tubes.
| Posted: Tue Mar 06, 2012 12:44 pm Post subject: |
Are they that much shorter eh? How much difference between the XG and XTRA focus yokes? ( size and electrically )
Jeremy112
| Posted: Tue Mar 06, 2012 3:17 pm Post subject: |
| CasetheCorvetteman wrote: | Jeremy, a P16 tube is an 8 inch tube, not a 7 inch tube. Any PG XTRA set has got 8 inch tubes. A PG plain or PG Plus has got tube larger that 7 inch but under 8 inch, and these are genuine NEC tubes, or E8508 tubes as they are named.
The HKA on the end is only the green tube |
I may have been wrong about the tube size, but I was still correct in that they wont work in an XG lol
A Rogers
| Posted: Tue Mar 06, 2012 7:50 pm Post subject: |
| CasetheCorvetteman wrote: | | Are they that much shorter eh? How much difference between the XG and XTRA focus yokes? ( size and electrically ) |
well I've got a xg751 with good red/blue but a bad green that I want to replace with on from my spare xtra. I just haven't been that inspired as my other XG with burned tubes still looks great. I might tear it apart and do the swap today/tomorrow so I can let you know the exact difference.
| Posted: Wed Mar 07, 2012 7:07 am Post subject: |
No worries mate would be interesting to know
| Posted: Wed Mar 07, 2012 7:12 am Post subject: |
I've tried it, and even if you can get the yokes to fit ( I think I cut the mounting clamps off way back when to get them to fit), the shorter tubes of the Xtra will not focus properly. that extra 1/2" is crucial of the XG tubes.
hansilili
| Posted: Wed Mar 07, 2012 8:19 pm Post subject: |
So that means the xtra yokes won't fit with the XG connectors? Whatever, if focussing doesn`t work the case is closed, right?
Motobias
Joined: 08 Jul 2008 Posts: 163 Location: Osnabrueck, Germany
| Posted: Thu Mar 08, 2012 8:02 pm Post subject: |
if he decides to sell the set, i might take it
i have a xg ac with worn green tube and looking for one...
got a really good red and a not to bad blue as spares, if he might be interested !
_________________ Most peope talk about HD without knowing the meaning and how to do it RIGHT !
FIGHTING STUPIDITY SINCE 1983
