scheimpflug G70
bachiano
Posted: Fri Feb 24, 2012 2:29 am    Post subject: scheimpflug G70
Is there anyway to turn off Blue defocus when doing scheimpflug using the H pattern on the g70?
I did the scheimpflug with the ME pattern within MG focus because I could not find a way to turn defocus off.
tanwn
Posted: Fri Feb 24, 2012 3:23 am    Post subject:
say your defocus blue is -5, just compensate back by +5. The slight defocussing shouldn't affect your scheimflug much by the way.Anyway you need a very slight defocus blue 3-5% to achieve uniformity of grey scale.
bachiano
Posted: Fri Feb 24, 2012 12:18 pm    Post subject:
Where do you go to change the defocus setting?
tanwn
Posted: Fri Feb 24, 2012 12:55 pm    Post subject:
You need to go into service menu and press MG focus button.
bachiano
Posted: Fri Feb 24, 2012 4:09 pm    Post subject:
my defocus was at 144 vs focus at 128.
What is the default defocus for the g70?
bachiano
Posted: Fri Feb 24, 2012 4:17 pm    Post subject:
ok - never mind - I found it.
+15 at 31.5 kHs
AFryia
Posted: Sat Feb 25, 2012 1:25 am    Post subject:
There is no default focus/defocus setting, each machine is unique in that regard.
You can disable Auto-defocus by pushing the MAG button twice. at least I think it is that button Wink All I know is that there is a button. You will see in the lower right of the screen "Defocus" toggle on and off.
However not all frequencies Auto-defoucs. There is a chart in the manual that will show how much red and blue de-focus is applied at each frequency. P4 and above have no defocus applied if memory serves me.
AFryia
Posted: Sat Feb 25, 2012 1:27 am    Post subject: Re: scheimpflug G70
I strongly recommend using the phosphor grain technique for scheimpflug.
That way you don't need to worry about focus either optical or magnetic.
bachiano
Posted: Sat Feb 25, 2012 1:58 am    Post subject:
AFryia
I Will try the phosphor grain technique.
What are good short throw binoculars to get for this?
AFryia
Posted: Sat Feb 25, 2012 5:41 pm    Post subject:
I picked up a 7X Nikon (7x35).
What I found is anything above 7X magnification would not focus very well at near objects closer that 12 ft. Just go to your local sporting goods store and try them all out focusing on near objects. Use a distance representing your PJ to screen.
