Glycol VS Techspray CRT TV Coolant
haireez
Posted: Thu Feb 23, 2012 1:26 pm    Post subject: Glycol VS Techspray CRT TV Coolant
Just need some advice between glycol vs Techspray Projection CRT TV Coolant.
I'm seeing fungus on my tubes and wonder if buying Techspray Projection CRT TV Coolant could solve my problem.
Link: http://www.mcmelectronics.com/product/TECHSPRAY-1915-16SQ-/20-4275
Does this CRT coolant perform better than glycol in term of picture quality? Rolling Eyes
2 White Vision 1
Ile
Posted: Thu Feb 23, 2012 3:22 pm    Post subject:
In theory 25% glycerine in crt fluid elevates glycols refraction index bit closer to acrylic/glass index, but in practice you can't see difference in PQ compared to straight glycol or distilled water. I haven't tested water and here it could cause damage during transport in winter time.
I wouldn't use ethylene glycol if you can see even small area of non coated aluminium in liquid chamber, because ethylene glycol corrodes aluminium. Commercial crt fluid should be tab better, because those have addition against corrosion.
Propylene glycol is one option, it shouldn't corrode aluminium, it's not hazardous like ethylene glycol and doesn't get ice like water. (probably not biggest issue there) I have used straight propylene glycol in air coupled tubes and mixed it with glycerin (75/25) in liquid coupled tubes. Both have worked fine for years.
dturco
Posted: Thu Feb 23, 2012 11:30 pm    Post subject:
My machine is Marquee 9500. I used Tech Spray when I installed bellows 2 years ago....I got fungus, or some slimy blobs. So no, Tech Spray will not stop it. Fungus is a reaction with the chambers.
http://www.hulu.com/firefly
haireez
Posted: Fri Feb 24, 2012 12:28 pm    Post subject:
I really would like to thank both of you for your valuable feedback. Initially I was about to order Techspray CRT coolant but now, I'm convinced to try propylene & glycerine (75/25%) combination.
2 White Vision 1
dvh99
Posted: Fri Feb 24, 2012 2:37 pm    Post subject:
wise decision.
that is what i have now in my chambers, could have sent me a pm Wink.
edit: distilled water doesn`t work, refractive index differs too much from the glycol glycerine mix.
geisemann
Posted: Fri Feb 24, 2012 4:33 pm    Post subject:
You have to clean the chambers with bleach and clean water to kill the bacteria. There is any screws that are of a different substance you need to coat the the screws to keep the reaction down. The bacteria comes from the screws.
Then refill.
Marquee has issues with this because the bellows are porous and I would recommend the upgrade as well there is a person selling new ones to replace your old . So you have a few issues.
Greg
www.eisemann-theater.com
jradwanski
Posted: Fri Feb 24, 2012 5:33 pm    Post subject:
what kind of glycerin should be used vegetable,animal,or synthetic they are all availiable in 99.5% pure solutions is ther a difference that we should be aware of?
dvh99
Posted: Sun Feb 26, 2012 11:58 am    Post subject:
1,2,3,propanetriol.
byproduct from soap making from different fats, vegetable fat, animal fat, shouldn`t make a difference as long as the chemical structure is the same.
