CRTVoyager
Joined: 02 Oct 2007 Posts: 16 Location: Bavaria, Germany
| Posted: Tue Feb 14, 2012 1:45 pm Post subject: Moome Card V1.3 Marquee - 9500LC - Problems with resolution |
Hallo CRT Fans,
since December last year I am the proud owner of a Moome Card V1.3 for my Marquee 9500LC. Installation in the CRT in SLOT 2 was fairly easy and after powering up the CRT everything worked just fine.
HDMI Connector 1: WD TV live Media Player with 1080p/60Hz
HDMI Connector 2: LG BluRay Standalone Player BD350 1080p/50Hz
First of all after setting the convergence switching the channels worked just fine.
Then a few days ago I started the BD350 and the picture with the menue of the BluRay Player wouldn't show. Instead I got a flickering picture which finally disappeared. Then a system message from my Marquee: V-sync is out of range.
By turning down the resolution to 720p I got a picture but way out of convergence.
On HDMI channel 1 with the media player things were just fine. 1080p/60 Hz.
So I thought may be the 1080p/50Hz from the BluRay player is the problem.
To get a result I switched cables and with the media player on channel 2 I got the same problems.
So how could it be that I have now problems with a 1080p resolution on channel one on the Moome card but only can run 720p on channel2?
Problem is that diffrent resolution means diffrent convergence and I'm no Pro in prgramming these settings into the Marquee.
Anyway maybe somebody knows what's wrong here. Any help is appreciated.
Greets Joe
