Making your own blurays from .TS files
Posted: Sun Feb 05, 2012 6:49 am    Post subject: Making your own blurays from .TS files
I have entire seasons of TV shows in transport Stream 1080i MPEG2 format. I'm in the process of editing the commercials out.
Should I deinterlace them before trying to make a Bluray disk?
Has anyone tried this?
Advice?
Posted: Sun Feb 05, 2012 2:36 pm    Post subject:
I was all ready to nuke this thread as I figured it was a spammer... Wink
Posted: Sun Feb 05, 2012 3:11 pm    Post subject:
It is a Spammer.
Posted: Sun Feb 05, 2012 4:42 pm    Post subject:
Jeremy,
There is no need to re-encode the files (which you'll need to do if you try to convert to 1080p). If you use a tool like VideoReDo, you can edit your commercials, and leave the rest of the video intact and unprocessed. It's fast and easy. The only frames that will be re-encoded are those frames between your edit, and the next I-frame.
http://www.videoredo.com/en/index.htm
