nuttall_chris
Joined: 08 Mar 2006 Posts: 832 Location: Ottawa, Ontario, Canada
| Posted: Tue Dec 05, 2006 1:45 am Post subject: Don't forget to bleed your tubes. |
I took the opportunity while having my projector off the ceiling to do some upgrades to bleed the tubes on my Marquee 8500.
When I removed the screw, the coolant literally sprayed out.
It looks like I did this just in time.
Don't be lazy....bleed your tubes.
Chris.
Joust
TV/Projector: Marquee 8501LC
| Posted: Tue Dec 05, 2006 1:51 am Post subject: |
I'll do mine too. maybe its a blessing that it is not tinted
the guys would laugh at you at work with pink and green spritz all over you.
nuttall_chris
| Posted: Tue Dec 05, 2006 1:53 am Post subject: |
Maybe I could convince them that it's the latest fashion 8)
Joust
| Posted: Tue Dec 05, 2006 1:58 am Post subject: |
you probably could. Most at that place are still wearing shorts with white socks and sandals.
Even though we got 4" of freezing rain on Friday and this mornign it was as cold as a witches titty.
In case you don't know, Chris and I work at the same co. in the same office complex but have still not even met each other.
nuttall_chris
| Posted: Tue Dec 05, 2006 2:46 am Post subject: |
Barry, once I have my beast put back together and on the ceiling you are more than welcome to come over and check out my setup.
Chris.
kal Forum Administrator
nuttall_chris
| Posted: Tue Dec 05, 2006 12:33 pm Post subject: |
I'd love to see your projector in operation Kal, I have never seen an LC projector.
Chris.
| Posted: Tue Dec 05, 2006 3:32 pm Post subject: |
I've never yet heard of the front glass on a 180DMB or DVB breaking. The seal
that keeps the coolant in place is extremely thick and water adsorption through it is virtually zero.
CJ
picree
Joined: 31 Mar 2006 Posts: 351 Location: Johnson City, TN
| Posted: Wed Dec 06, 2006 4:43 am Post subject: |
Why do they build pressure?
_________________ MAIN THEATER: (JVC RS2000; Yamaha UDP-LX500; Yamaha RX-V2400; Lumagen Radiance Pro, Vertex)
SECOND WII-ATER: (BG808; WII; Oppo 971H; Moome external box; BG-DVI transcoder; tse gamma box; Extron)
jask
| Posted: Wed Dec 06, 2006 4:50 am Post subject: |
The coolant in the chamber picks up moisture from the air over time and expands in volume
Joust
| Posted: Wed Dec 06, 2006 5:02 am Post subject: |
| cmjohnson wrote: | I've never yet heard of the front glass on a 180DMB or DVB breaking. The seal
CJ |
Cool, I'd like to put that particualar worry out of my head but....
If thats the case, then why would Chris's tube spray like that?
I saw pics somewhere of the front glass broken. Not sure what type of tube it was.
nuttall_chris
| Posted: Wed Dec 06, 2006 12:44 pm Post subject: |
Maybe the glass on my tubes would have been fine for a long time but it only took about 20 minutes to drain them while I had my projector pulled apart for some other mods. Well worth my time.
SYC
| Posted: Wed Dec 06, 2006 2:55 pm Post subject: |
Do I have to remove the deflection coil, the focus coil, and astig magnets like the movie shows?
SYC
nuttall_chris
| Posted: Wed Dec 06, 2006 3:41 pm Post subject: |
| SYC wrote: | Do I have to remove the deflection coil, the focus coil, and astig magnets like the movie shows?
SYC |
No you don't have to remove the magnetics.
Chris.
SYC
| Posted: Wed Dec 06, 2006 9:25 pm Post subject: |
[/quote]
Chris.[/quote]
Only the magnetics don't have to be remove? Or all of them?
SYC
| Posted: Wed Dec 06, 2006 10:06 pm Post subject: |
| Joust wrote: |
In case you don't know, Chris and I work at the same co. in the same office complex but have still not even met each other.  |
He's lying, everyone knows everyone else in Canada.
jask
| Posted: Thu Dec 07, 2006 2:33 am Post subject: |
| Curt Palme wrote: | | Joust wrote: |
yup its true
and... on Thursday nights (Wednesday in Newfoundland) we all get together, play hockey,drink beer and build Inukshuk http://www.thecanadianencyclopedia.com/index.cfm?PgNm=ArchivedFeatures&Params=A29
out of empty cases of beer...
nuttall_chris
| Posted: Thu Dec 07, 2006 2:46 am Post subject: |
[quote="SYC
SYC[/quote]
As long as you can access the screw on the side of the tube to drain the glycol, everying else can stay on the tube. All the magnets and coils can remain on the tube the only thing you will have to remove is the neck card.
But be careful not to get glycol on any of the magnets or coils as I believe it can cause damage.
Chris
Fujifrontier
Joined: 20 Oct 2007 Posts: 354 Location: San Antonio, Texas
| Posted: Sat Oct 20, 2007 3:09 am Post subject: |
Am I correct in assuming that if you don't move any of the magnetics, the only thing you'll have to do is the grayscale adjustment and the digital convergence, after you put the tube back in?
