Kevink
Joined: 08 Jan 2012 Posts: 3 Location: Portland, Oregon
| Posted: Mon Jan 09, 2012 12:06 am Post subject: XG-FULLHD HDMI V1.3 card not powering up |
I just installed a new Moome XG-FULLHD HDMI V1.3 card into an NEC XG-135. When powering on the projector, there is a brief flicker of the two red lights above the HDMI inputs and then nothing. None of the lights turn on. This is true when the card is in either the B and C slots.
The projector continues to function beautifully via RGB.
When I connect a DVD player to the pj via an HDMI cable, the green connection light above and between the two HDMI inputs lights up, but that's it.
Needless to say, I am not getting any kind of image.
I have fresh batteries in the remote. Nothing I do with the remote seems to change the situation.
Do I have a faulty card or am I failing to do something obvious with either the card or the pj? Any suggestions would be greatly appreciated. Thank you.
ps Where does one find an email address for Moome?
| Posted: Mon Jan 09, 2012 12:26 am Post subject: |
Try a BluRay player with HDMI output set to 480p with a short cable, say 6' or so. BR to Moome directly, nothing inbetween. See if that works. If not, then I'd say you have a bad card.
dturco
| Posted: Mon Jan 09, 2012 12:59 am Post subject: |
On the remote push the #1 button if nothing happens push the #2 button. This tells the Moome card which HDMI input to read. Have your source on when doing this.
Hope that cures it, if not I have no idea.
http://www.hulu.com/firefly
Kevink
| Posted: Mon Jan 09, 2012 2:20 am Post subject: Moome's Shipping Address |
Thanks for the suggestions. Unfortunately, the card is still dark.
Anyone know the shipping address for returns to Moome?
Thank you!
