Advent Granite Sub woofer
Posted: Sun Jan 08, 2012 6:52 pm    Post subject: Advent Granite Sub woofer
A delivery guy who comes to my Diner drooped off a Advent Granite Sub to look at.
The Volume and cross over pots were dirty and I cleaned them first with Tuner cleaner and the
sub worked for a little while. I shut ti down and came back to it and no go. The signal light on the front
would not show an incoming signal. I dont think the Amps are bad just the inputs. I tried only the line level
not the speaker inputs. The owner said even those did not work so I didn't bother.
I cant find schematics anywhere or even info on this sub besides on a few forums.
I dont think its worth it to fix but you know how people are.
Any leads guys?
Posted: Sun Jan 08, 2012 7:35 pm    Post subject:
There should be a model number on it somewhere.
Posted: Sun Jan 08, 2012 7:38 pm    Post subject:
I looked all over the cabinet and found nothing.
I have the amp on the bench and will get any serial numbers but I did not see any other
model numbers etc. maybe I over looked it, i'll check when I get home from work.
Posted: Sun Jan 08, 2012 7:40 pm    Post subject:
What size woofer? Any year sticker on board?
Posted: Sun Jan 08, 2012 7:42 pm    Post subject:
looks like a 10 " from memory. I'll check in an hour or so when i get home.
Posted: Mon Jan 09, 2012 12:05 am    Post subject:
Ok It is a B2R series on the inside of the amp on the aluminum plate/heat sink are these stckers:
IJI
3701 44 971
the Amp board is: 02-01474-02
Volume/cross over board: 02-01567-01
Input board: 02-01566-01
I think it has to be something on the Input board:
There is a switch that has on, auto and off. in off the led on the front is green, if in auto or on its yellow.
I do not have the remote for it.
Posted: Mon Jan 09, 2012 12:39 am    Post subject:
No good on any prints. You'll have to shoot from the hip. If you get stuck let me know and I'll give you some direction.
Posted: Mon Jan 09, 2012 12:41 am    Post subject:
All the caps seem fine, There are a few transistors etc on the input board I'll have to test those next.
I'll try to take some pics of the input board later and post.
Thanks mac
Posted: Mon Jan 09, 2012 12:44 am    Post subject:
You may want to test the speaker just to make sure it's ok.
Posted: Mon Jan 09, 2012 1:00 am    Post subject:
it is, it was playing before. I had it runing and the signal indicator was lit. I shut it down and went to turn it on again with in a few minuts and no go. No signal indicator light. Just the power light. Changing the switch for on,auto,off changed the led color from yellow,yellow,green respectively.
